282Views28Replies
Does anyone know a jamless red rod knex magazine for a repeater?
Does anyone know a jamless red rod knex magazine for a repeater? Clip size doesn't matter, and it isn't neccesary to be removable. If it uses a pusher then don't post it in your answer.
Best Answer 11 years ago
Why don't you try a "funnel" mag? Basically, you have a chamber with a small gap above it (enough to fit 1 rod in) and then it branches out. Then, if you really want to, add a flat sheet as a pusher. It should look something like...
....|..| <-- Chamber
....|_|
Answer 11 years ago
Seems like a great system to me, I'll try it out.
11 years ago
Here are 2 jamless red rod guns.
https://www.instructables.com/id/Red-Impact---Perfect-Duck_s-K_nex-gun./
https://www.instructables.com/id/K_NEX-AST-RIFLE/
Answer 11 years ago
red impact is not a jamless gun
Answer 11 years ago
Red impact has a thingy that separates the rounds in the hopper from the round shot. It doesnt jam thanks to the open design too.
Answer 11 years ago
It isn't? Cause many others pointed out it is jamless.
Answer 11 years ago
well the blue rod thing that hist the ammo sucked and the ammo arm wouldnt work correct
Answer 11 years ago
Ah, i see, I had these problems too. Do you have a spring btw?
Answer 11 years ago
at first no then i got one and the same thing
Answer 11 years ago
It never did for me.
Answer 11 years ago
Answer 11 years ago
Never happened to me.
11 years ago
Well, even though 'Killer~Safe~Cracker' already pointed you to some mags, they are almost certainly not jam-less. Magazines, without a BA system will never be completely jam-less.
Answer 11 years ago
Both of them never jammed for me. BTW: It's Killer~SafeCracker. Just want every one to get it correct.
Answer 11 years ago
Sorry, I was just typing your username from memory. Also, I meant that it would jam if you just kept firing for like a year... Even that would make it not-jamless.
Answer 11 years ago
Thats fine. Even if a gun was BA that doesn't mean that it would never jam.
Answer 11 years ago
Well, true...Much less likely though.
Answer 11 years ago
And why is that??
Answer 11 years ago
BA? What does that mean?
Answer 11 years ago
Oh, Bolt Action. I forgot you aren't on KI. (KnexInnovation.net)
11 years ago
yes! Perfect Duck's Red impact is perfect
these are just two that i found, but there are many others.
11 years ago
I have build and tried the Red Impact and it does not jam, as long as you get the parts right, and on the good side, its got a silver banner
11 years ago
red impact
11 years ago
Turreted guns like knexsayer and BR-18 can fire red rods.
Answer 11 years ago
Sorry, I need a reguallar mag, the turret would be too large, and wouldn't be able to support enough rods. I appriciate the idea though, maybe on my next knex gun?
Answer 11 years ago
I thought you said size doesnt matter. and anyway, ajleece made a compact version of the BR turret. Its an oval, and its not bulky.
Answer 11 years ago
So did I, 8 shots, as big as a white connector.
Answer 11 years ago
that is a circle. And AJ's turret was 24 shots.
