3641Views17Replies
Does anyone know any tips for recycling tires at home.? ?
I was just curious if anyone had any tips for recycling tires at home on the farm? Also any uses? Seems such a terrible thing on te enviroment with so many tires and not nthing to do wih them.
Best Answer 10 years ago
Potato tubs for early spuds
Cut round the edge and turn the tire up to form a planter, paint white.
Answer 10 years ago
Like this then?
L
Answer 10 years ago
Thats pretty neat . I did not know if i shreaded them was there any commercial use. basically there is a old dump dow the road that has several hundred in it. I was curious if there was use fo rthem if i shredded them. maybe even a part time buisness or something. They will never decompose.
Answer 10 years ago
or a path covering to replace gravel
Answer 10 years ago
shredding is relatively easy for us. I only wish they were a way we could ue thm as fuel somehow with killing everything on the planet.
9 years ago
Cut-off the side-wall with a heated blade, leaving the flat-tread. Cut the tread into sections, drill a centre hole at the top of each piece and use for roofing tiles, wall-shales or glue-down for floor tiles.
9 years ago
How about a fish pond?: https://www.instructables.com/id/Fish-pond-from-tractor-or-car-tires/ (pics 1 & 2)
Or a rainwater tank using the same principle as above but with really big tyres
Or garden beds: (pics 2 & 3)
Or constraining beds for invasive plants (mint, sugarcane, etc) (pic 2)
Or tarpaulin weights: (pic 3)
Or set on edge half buried as carpark bumpers (won't damage car!)
Or Earthship houses / retaining walls
OR: footware, garden trugs, belts, bracelets, air pump, bike/boat fender, swings, sharpen sandpaper, rocking/gaming chair, compost bin, etc - all found by searching Instructables for "tire OR tyre" or "used tire" or "Does anyone know any tips for recycling tires at home.?" ; ]. Not to mention searching the 'Net.
The possiblities are limited only by our imaginations! Used tyres are a huge "resource" - I'd love to see what novel ideas we can come up with...
10 years ago
rammed earth tire is the coolest thing i've seen with them lately. You basicly lay the tire down, fill it with dirt, pound the dirt with a sledge hammer, more dirt, more pounding, dirt, pound, dirt, pound, untill it's a tire with super packed dirt in it. Then you could make an earthship like Hedvigm said or whatever else your heart desires.
10 years ago
You could always line it with a polythene bag if that was a worry though
10 years ago
me and my mom are currently making a tire playscape it is durable and bouncy (good for kids)
10 years ago
10 years ago
My brother made some shoes out of them once. He just cut out the shape of a shoe sole... then nailed it to the soles of another shoe whose soles had worn out. ALSO.... I once saw a farmer on tv who put them into a big hopper and heated them up... then it kind of "DISTILLED" them into diesel fuel... and a burnable kind of natural gas... and something else i cant remember.
Answer 10 years ago
That would be gasification - there are a few projects on that theme here.
10 years ago
Some people make awesoem sculptures from them:
http://blog.jonathanhearn.com/2010/01/tyre-sculpture.html
Some people make bags from them:
http://www.ecofriend.org/entry/dads-eco-friendly-baby-case/
or belts:
http://rarebirdfinds.typepad.com/rare_bird_finds/2009/02/bicycle-tire-belt.html
(Would also be good for making a Mad Max costume.)
If you burn them make sure you burn them in a furnace that's made to do it. Burning rubber at standard temperatures will create tons of pollution. There are special furnaces that run at high temps that will also burn off most of the polluting gasses.
10 years ago
There are several industrial uses for them. Some are actually melted/burned for fuel. There is a lawn watering system "leaky pipe" made from ground tires that are then made into tubing that leaks to water in strips. Woven door mats? There is not much else to do with old tires and way too many old tires to do something with.
10 years ago
I have been told that farmers and ranchers (in the Western U.S.) sometimes dug a trench and lined the tires up in it in a row to make a "pipe" or "tunnel" then backfilled the trench (leaving the interior tire space open) and then used it as a septic drainfield, rather than using perf pipe. If you did it, I wouldn't tell the authorities about it.
10 years ago
Use 'em for planters ?
