43122Views13Replies
Does anyone know how to dry a liquid to make a powder?
I want to make stevia powder out of a concentrated stevia liquid? To store it longer and to use it in dry tea mixtures and so on.
1 year ago
I want to turn tomato puree into powder. What do I need for that? Any ideas?
Reply 1 year ago
I did this by lining my dehydrator with parchment paper (so the liquid didn't go threw the slats, they also make special trays you can buy) then I let it dehydrate until it was no longer shiny or flexible. To make it a power I ground it in a food processor. (Hope this helps).
9 years ago
Another thing that would work is one of those small food driers, the ones they use for fruits and berries and such.
Answer 9 years ago
Do you have any expereance with such food driers? Can I use a food drier for liquids? A food drier dries the inside stuff, by making the stuff warm inside and the liquid comes out of the stuff? What about an oven with an open door? The heat above 50°C and under 100°C so that nothing burnes inside?
Answer 2 years ago
Have you tried oven method yourself? I want to make ACV powder so keen to know :-)
6 years ago
vacuum concentration/distillation may work. essentially putting the liquid under a vacuum causes the liquid to boil without having to heat it as much/at all. A rotary evaporator would do it but costs 2,000-15,000. alternatively you could hook a sidearm flask to a vacuum pump on a stirring hot plate for much less but it would probably take longer. A spray dryer would work but similarly costs a lot, however you can replicate the process with inexpensive tools (essentially the theory is that a slurry such as your stevia liquid is sprayed to fine particles into a hot chamber (350F+) and dried by the heat). It's touchy because too little heat will do nothing and too much will burn the powder but I've seen it done with a paint sprayer and a heat gun in an enclosed container (e.g. a pipe or trashcan depending on scale)
Answer 6 years ago
+1
6 years ago
how to convert liquid dicetylmorphine to powder?
6 years ago
I love instructables! The best machine would be a lab-sized (aka "benchtop" or "table top") rotary drum dryer, since the split second the liquid hits the stainless drum it solidifies, and is instantly scraped off. Buflovak makes them, but they are very expensive:
http://www.buflovak.com/VacuumThermal/Products/Sin...
Image 1: Rotary Drum Dryer (Lab Sized)
Here is an equally-effective approach, frequently used in labs to turn liquids into powders. Cellulose fiber is natural plant fiber to make stems erect and strong (think celery). Cellulose absorbs many times its weight in liquid, such as stevia liquid. A commercial form of cellulose called "SolkaFloc" absorbs many times its weight in liquid. You would soak the cellulose with Stevia liquid, then dehydrate it in the sun, or using a home dehydrator.
Image 2: Powdered Cellulose Fiber
Dehydrate the soaked cellulose at 125-135 degrees. The water should dehydrate rapidly due to the cellulose's high surface area. Drying options include a home oven, a mini clothes dryer, or a food dehydrator.
Image 3: Mini Clothes Dryer
Image 4: Home Food Dehydrator
When dry, grind it using a coffee grinder: the kind with burrs give the most uniform particle size, but you could use a rocket blender.
Image 5: Electric Ceramic Burr Coffee Grinder
Image 6: Hand-Crank Ceramic Burr Grinder
SHOPPING: WHERE TO BUY IT
Buy a Bella rocket blender at Wal Mart:
http://www.walmart.com/ip/24722307?wmlspartner=wlp...
Buy a hand-cranked ceramic burr coffee grinder:
http://www.thinkgeek.com/product/f2ff/?itm=customl...
Get an electrified ceramic burr mill at:
http://www.wayfair.com/Capresso-Infinity-Conical-E...
Buy the SolkaFloc cellulose from International Fibver Corp in Tonawanda, NY:
http://www.ifcfiber.com/applications/pharm/tablets...
Buy a shelf-type food dehydrator from:
http://www.sausagemaker.com/32709tsmharvestfooddeh...
Order a mini clothes dryer tumbler from:
http://www.target.com/p/haier-2-6-cu-ft-portable-e...
9 years ago
I believe that is called freeze-drying. I have always wanted to know how to do that but I never had the equipment to do it.
9 years ago
The difficult thing is usually getting the liquid to evaporate quickly enough to keep it from being olonized by microbes (fermenting at best, getting moldy at worst), and without cooking the material or driving off essential oils you want to preserve, either of which could change its flavor.
Have you considered just freezing your concentrate into ice cubes, perhaps using one of the plastic trays which makes 1/2 inch cubes? You could then just toss an appropriate number of cubes into whatever you're using. (Credit for this approach goes to Ewel Gibbons, who used it to preserve jewelweed extract for later use.)
Answer 9 years ago
+1
As has been noted, making dry liquids is usually done using a vacuum process. Using conventional dehydration will evaporate all the aromatic oils from your Stevia, and it will potentially introduce harmful bacteria or simply result in spoil, so freezing in convenient measurements is probably the best you can hope for at home.
9 years ago
Just to evaporate it ? The big guys spray into vacuum chambers I think, so that flavours are preserved. Big open tray in the refrigerator, and mount a PC fan tray over it ?
Answer 9 years ago
You mean refrigerate the liquid? How do I have to mount the fan on the tray? Do you have a sketch of this idea? It sounds good.
Answer 9 years ago
Take it ( your liquid ) down to the triple point.
That is what I think Steve was alluding to.
Takes a big sucking vacuum chamber :-)
