737Views7Replies
Author Options:
Does anyone know how you would build a temperature controller for a (Peltier effect) thermoelectric plate? Answered
I want to be able to control the temperature.
steveastrouk
steveastrouk
11 years ago
Do you want bidirectional control ?
What current rating is the device ?
How accurate do you want the control to be ?
Do you want the thing to be closed-loop controlled ?
I_AmThe_Eggman
I_AmThe_Eggman
Answer 11 years ago
Well I don't really know. What I really want to do is be able to change temperature, of lets say a liquid, from x degrees to y degrees. As far as accuracy, I would hope the closest possible. As for bidirectional control, rating, and closed-loop controlled, I have not yet purchased a device. Any suggestions? Thank you for your time and help.
steveastrouk
steveastrouk
Answer 11 years ago
If X and Y are outside the sensible range of the device, then you can't ! You need to know what temperatures you want.
I_AmThe_Eggman
I_AmThe_Eggman
Answer 10 years ago
Well I want to heat water to 37 degrees C.
steveastrouk
steveastrouk
Answer 10 years ago
What volume of water, or volumetric flow rate ? You're right, you need a Peltier cell for the best control at this kind of output temperature
Steve
I_AmThe_Eggman
I_AmThe_Eggman
Answer 10 years ago
Maybe about 2.5 L of water. Thanks for the help again. Going to start trying to work on this.
