538Views7Replies
Author Options:
Does anyone know hows to repair a thin cable? Answered
Hi,
I have worked on an old version of robot Nao, and recently discovered that a thin cable (see picture) from its shoulder is broken, the thin cable is very tiny, slim and can be quite fragile. I understand that I have to send it back to Aldebaran to repair, but it really costs a lot and it takes time too.
Can I ask if there is anyone out there who is specialized in repairing this kind of cable? I appreciate much of your help. Thanks a zillion!!
Awesome-aniac
Awesome-aniac
9 years ago
Perhaps you could just buy a roll of ribbon cable and replace your cable.
cassandraanabellum
cassandraanabellum
Answer 9 years ago
but this cable is made by aldebaran, this kind of cable cannot be found in market. Do you have any way that i can contact with a professional who is profession in repairing cables?
Thanks!
frollard
frollard
Answer 9 years ago
You might not find the EXACT cable - but a suitable replacement can probably be found -- the only important thing is number of conductors and spacing of the pins.
Awesome-aniac
Awesome-aniac
Answer 9 years ago
From the picture above, it looks like it could be soldered. It all kind of depends on how small of a space the cable has to go into. Where soldered, it will no longer be flexible and will be slightly thicker.
theoldguy
theoldguy
9 years ago
Scraping insulation off really thin cable is frustrating and a real pain in the bum. Heat the insulation and remove the insulation when it is hot. it won't take much heat. I use a heat gun but a candle will do as long as you clean the strands before soldering. I use finger tips as I don't care about tiny burns, but a cloth will do the same job.
I assume that once you have cleaned the insulation off the cables you have a way to join them.
rickharris
rickharris
9 years ago
Scrape off the insulation and solder a wire across the broken section.
OR replace the entire thing with separate wires - they only use ribbon cable for convenient assembly.
