60992Views15Replies
Author Options:
Does anyone know of a electric air conditioner that runs off of the cars D/C or using a A/C converter Answered
does any one know of a air conditioner that could be used in a car, that runs off of the D/C current of a car of using a converter to use A/C power. I am trying to aircondition my car without using all the gas from when the compressor is on. Any ideas or suggestions? possible even solar energy if anyone knows enough about this.
PhilippeD3
PhilippeD3
1 year ago
I know this is an old post. I currently have a 130 Amp alternator. I can get a 200 Amp alternator. That is a gain of 70 Amp. I loose about 1 HP per 25 Amp. so about 3 HP. If I used that Amp gain to feed a DC to AC inverter, with a 115V EV compressor replacing the belt driven A/C I figured I would not loose any power. I read that an A/C would require about 50A to run. does this sound realistic ?
I have been fighting with my car to not overheat (everything else from radiator, hoses, thermostat,Ac clutch have been checked out by the pro's, but whenever I am in stop/go in 90+F weather, My car starts overheating with A/C on, but returns to normal without it. I thought this might be a solution.
jamesautodude
jamesautodude
Reply 11 months ago
This is 100% something to do with your outdoor airflow. Something is wrong with 1 or both of your fans, or you have some junk blocking the fins. The fact that it mainly happens with the air conditioning is telling me that your condenser fan is bad. But could also be a blockage
BruceN15
BruceN15
Reply 11 months ago
sounds simple, but did you check if the radiator fans are working? there 2 usually 2 radiator fans, they also cool teh condenser. a competant mechanic should be able to find teh source of the overheat. you may have a clog restricting flow in the radiator, you may have a water pump worn down causing slow coolant flow throughout the cooling system. it could be many things. making a dc air conditioner is not the solution, finding out whats wrong with your car is. also yes there are DC air conditioners for cars, from china, 1 major model and well here look at these
https://www.ebay.com/itm/Micro-DC-Air-Conditioner-Kit-DC-12V-450W-R134A-Powerful-Air-Conditioner-for-Car/293381511393?hash=item444ee698e1:g:SlcAAOSw4khd-P2M
and especially this is the major selling one look:
https://www.ebay.com/itm/12V-DC-car-air-conditioner-for-Truck-Crane-Parking-and-Retrofitting-Hanger/333351514634?hash=item4d9d4c720a:m:mMPeakoE3nExNqCn0k_lJzw
search for 12v dc air conditioner rv, or something like that on ebay and alibaba, you will find tons on alibaba. $750 is the one you want, you see the picture I attached with a compressor in it? it is DC powered 7,000 btu
BruceN15
BruceN15
11 months ago
vaughnrichardallen
vaughnrichardallen
1 year ago
Alot of these people posting here seem to be under the false assumption that a car air conditioner is small or only uses 1000 watts. A car has massive windows and almost no insulation on the roof or doors so it leaks alot of thermal energy and this requires pure muscle to overcome. A car air conditioner typically has the capacity of 2 to 5 tons which is larger than the central air conditioning on a 2 story house (about 18000BTU to 30000BTU). This works out to about 3000 to 6000 watts! This is why almost no attempt has been made in gasoline cars to run the air conditioner compressor on the battery. Electric cars run the compressor directly off of the high voltage DC battery which actually reduces the range of the car significantly. 3000 watts of solar panels works out to about 8ft by 30ft which is way to large to place on the roof of a car. Maybe if you had a stretch limo you could cover the roof with panels and run the smallest car air conditioner available.
Doko
Doko
11 years ago
There is many cars that use air conditioners running purely on electricity today. Almost all the hybrids have it. Try to buy a Toyota Prius used air conditioner system (inverter + compressor + heat exchangers), if you are in US it will not be hard to find it. You will need also an DC to DC converter to obtain the DC voltage that this compressors need from the batteries (tipically over 100V). Another possibility is to buy a standard 115V room air conditioner and use it with an powerful 12 to 115V inverter. The problem with this approach is that standard air conditioners are not designed to shake a lot, so the life of them when used in mobile applications is very limited. It is also possible to drive the standard air conditioner in your car with an independent electric motor, not from the main engine of the car, but this motor is not a small one... You will need a 1 or 2 Hp motor to do that. And remember that car air conditioners (like many other car parts) are designed to work for just 5000 hours. So if you run it for 8 hours per day or so the AC will last only for 600 days of so. Forget about solar energy... You will need a solar panel bigger than your car do have energy enough to run the air conditioner. Yes, air conditioning uses A LOT of energy. If you will use it just during the night, the air conditioning will need a 100 A.hour battery or more to do the job if the main engine is off. During the day the power consumption is tremendous due to the radiating energy from the Sun, so you will need three of four times more energy (you need a truck battery to do that). This problem with the power levels is the reason why the automobile industry has chosen to run the AC directly from the engine. And also the reason why when you turn on the airco, the consumption of the motor increases... No possibility of free lunches in nature...
rbarzin
rbarzin
Answer 8 years ago
its very interesting, actually we are looking for very low power air conditioning system (as powerfull as a normal car) for research application with low price.
it should run purely on electricity.
we need to use it in our model houses (they will not be moving). could you suggest us
JoeyCool
JoeyCool
9 years ago
Don't know if this will help you, but . . .
Grassroots EV has an electric A/C unit for EV cars (for the EV Hobbyist) called COOL BLUE which is claimed to use only 500 watts (120v 60Hz AC). coupled with the (I think) BLUE FLASH (DC/AC Inverter); this should get you in the ball park.
Also: a 12 D.C volt to 120 A.C. Volt Inverter from the Inverterstore.com may have the inverter you are looking for. I would recommend at least a 1000W to 1500W inverter for the COOL BLUE unit. This DC to AC Inverter would change the 12volt from the car to the necessary 120VAC that the COOL BLUE unit needs. (the higher power rating is for safety purposes).
Remember that you would need to use a considerable amount of power from the car's electrical system to power the DC to AC inverter (500W at 12v = aprox. 49A, and at 90% efficiency probably 55A) This IS a lot of current.
My disclaimer: Always consult the manufacturer(s) of both the car and the COOL BLUE unit on this idea to see if this is feasable.
JoeyCool
robosan
robosan
9 years ago
I wish I knew how. But let me tell you. There is a car that is not yet in production which has a small cabin and possibly good insulation, and because of that, they are able to keep the cabin cool with a smaller AC unit that is powered by a small solar panel on the roof. I am not sure how cool it gets, but they claim is good enough. I haven't seen any tests under 115 degree sun, though. And I sure hope it lasts longer than the 5000 hours that Doko, above, states.
Check it out, anyway. www.aptera.com
Also, think insulating the car ceiling, doors and walls, and put reflective film on your windows. In southern florida you will have a hard time finding a car which doesn't have some kind of heat and UV reflective film installed. Still, I constantly see cars in parking lots with the engine on and ac at full blast, and kids watching a movie and waiting for mom to finish shopping. We can't change people, but a solution to this problem would cut a ton of CO2 emissions.
FixitmanArizona
FixitmanArizona
10 years ago
Might look into something like this. This unit doesn't have a housing or anything and already hooks up to 12 volt. I'm not sure what the specs are for air movement/ cooling capacity, there are specs there, but it's a foreign language to me. So far, I haven't found a commercial product using this, but maybe I haven't looked hard enough. I think these were designed for computer server towers. http://www.tellurex.com/products/thermoelectric-a45.php
Tommy W
Tommy W
11 years ago
https://www.instructables.com/id/Portable-12V-Air-Conditioner---Cheap-and-easy!/
hendrosutono
hendrosutono
11 years ago
You dan make on using Peltier thermoelectric plate... it's using 12v DC directly..
maybe this link will help you...
https://www.instructables.com/id/diy-chiller/
steveastrouk
steveastrouk
11 years ago
How are you using this car ? Is it stationary when you need to use the air-con ? And near a power point ? Power levels: A car aircon, on full, I'd guess, is probably 600W - 1000W of cooling. If you have the space, you could add a means of running the air con by beltdriving the thing with another motor, clutched to the air-con compressor by an electric clutch, like the car uses to turn ON the air con ?
lemonie
lemonie
11 years ago
Using a DC to AC converter and another unit is going to be less efficient then using the car's own Air-Con'. If you can get a decent solar power supply: feed it into the battery. L
