102Views11Replies
Author Options:
Does the ceiling cause interefence for cell phones? Please help? Answered
I have noticed that when my cell phone rings and I'm in the building (with ceiling), the signal is interrupted every so often. However, when I go outside,the signal is clear. What else could cause intereference in cell phones?
lemonie
lemonie
11 years ago
How often are you in buildings without a ceiling? see ZEROGX
L
Kiteman
Kiteman
Answer 11 years ago
I'm guessing he means false or suspended ceilings.
If he does mean suspended ceilings, I'd say "potentially, yes", since there is a lot of metal strung up above a suspended ceiling.
lemonie
lemonie
Answer 11 years ago
There's a frame yes. In such buildings you might also have a steel frame or reinforced concrete too?
L
Kiteman
Kiteman
Answer 11 years ago
Indeed.
Plus aluminium flashings and sidings, metallised glass, and poorly-installed electrical equipment broadcasting across most of the spectrum.
lemonie
lemonie
Answer 11 years ago
Them too. Stand on the roof?
L
Kiteman
Kiteman
Answer 11 years ago
I think the author's "outside" option is probably safer...
lemonie
lemonie
Answer 11 years ago
It's still outside.... (thinking flat-roof)
L
seandogue
seandogue
11 years ago
 Some buildings have corrugated metal roofs that can interfere with reception, and worse are those that are built as pole barns, both roofed and sheathed with metal
Re-design
Re-design
11 years ago
Lots of commercial buildings have roofs that are made of sheet metal.  That pretty much stops a signal from the top.  The walls may have metal only where the col's. are and wood, masonry, insulation and sheetrock spanning between them, or they may be sheeted in metal also.  again if sheeted then the signal is going to be pretty well attenuated.
If you're having trouble in one spot move a few feet to the side and you may bet better reception.
frollard
frollard
11 years ago
Agreed with Zerogx and lemonie - cel phones don't get their signal (99.99% of the time) from satellites.  It comes from towers, and unless your tower is right next to your building, you're getting signal almost horizontally.
Walls and crap in them blocks signal.
gmxx
gmxx
11 years ago
 it probably is going to be the walls mostly. you will get better reception by windows. the thicker materials in the wall parts, combined with the metal a/c ducts, power/data lines and whatever else just kills signal.
