261Views5Replies
Author Options:
Double a power source's output ports? Will this divide the amperage? Answered
If I hooked a 4v 4amp battery up to 2 devices which each require 4v and 4amps, will the amperage supplied to each device be equal divided? Or will it just not work?
V-Man737
V-Man737
Best Answer 11 years ago
Yes, they are wired in parallel, so it's as if they each have their ownconnection to the power source.
Now. There is a difference between how much amperage a battery can source, and how much amperage the devices draw. In this scenario, the voltage will remain the same, but yes, to answeryour question, the amperage will be divided between the two devices -- not the amperage they draw, but the amperage the battery can provide. Ifyour battery sources a max of 4 amps, then the devices will only beallowed 2 amps each. If your devices don't need half as much amperage asyour battery can source, then you'll be fine.
lemonie
lemonie
11 years ago
4V is a bit unusual, but if it'll only supply 4A and each device needs 4A, they won't work.
L
nepheron
nepheron
Answer 11 years ago
its just theoretical.
kelseymh
kelseymh
11 years ago
As drawn, the voltage will be 4V to each, and therefore the amperagewill be divided.  Energy conservation.
Re-design
Re-design
11 years ago
It will be divided equally if they both draw the same amount of power.
Your power source can only put out so much power.
