373Views4Replies
Author Options:
Dragon's breath. Schematic needed, 10 LED's chase, appear the flame to be "blowing", light in sequence, repeat Answered
Tags:auto
tinkerunique
tinkerunique
10 years ago
The "Dragon" is a design cast into the spare tire cover. I have a black denim cover, the "face" has been fiberglassed - dragon applied over that - coated with casting resin < so the dragon shows thru. Result = a flexible cover with a flat/hard surface that I intend to "LED-up" when the brake light comes on. May only be visable in darkness. I want the "fire" to appear to be blowing - not just a static display. < 14" in length ) There will be 10 - 13 12v. LED's. I would like 2 or 3 pairs to light at the same time, if possible. The 555 + 4017 IC's seem best suited to handle the voltage,
AndyGadget
AndyGadget
10 years ago
Data input insufficient. Elaboration required. Standard English permitted.
tinkerunique
tinkerunique
Answer 10 years ago
12 V. (auto) > 555 IC + 4017 IC - to 10-13 LED's. > backlighting in casting resin 'picture of fire-breathying dragon. LED's cast into the resin of the "fire" and chase when the brake lights come on. What ( if any ) resistor is needed before the IC's. I can get 12 v. LED's at Radio Shack. Will the 4017 IC power two LED's coming out of a single pin ? The schematic is of a simple 10 LED chaser The IC's seem to be capable of using 5 -14 volts The capacitors regulate the speed of the "flash"/sequence. There will be 10 to 13 LED's along the length of the "flame"
AndyGadget
AndyGadget
Answer 10 years ago
This sounds perfectly do-able but can you give a link to the circuit you're using? You may need to beef up the current to drive 2 LEDs. How big is the resin casting - Are we talking something on a car or is it a sculpture?
