289Views5Replies
Author Options:
Driving DC brushed motors with Pi/PWM/Arduino? Answered
I have a few motors (2) that i would need to be able to drive via a PWM input (Probably from pi/arduino). I have been looking at H bridges, and that seems to be my answer, however, I can't figure out which one i need... The motors are identical 9v ~2 amp stall current motors. I would need both directions for each, and would obviously be using an external power supply.
With that said, which H bridge would suite my needs, along with what type of setup? I only have abut 4-6 PWM pins left to use, if that helps.
steveastrouk
Best Answer 4 years ago
One motor needs one PWM output, and one direction control digital pin. So long as the H bridge will take the stall current, you have a pretty free choice.
RocketPenguinsteveastrouk
Answer 4 years ago
So an H Bridge uses two pins, not counting ground? And as long as the H Bridge can handle 9v and ~2 amps, it should work? I assume they also have an input for external power supply for the motor?
I found this http://luckylarry.co.uk/arduino-projects/control-a... , and its basically what i would need, but according to the spec sheet, it can only handle 600mA... Any chip that works similarly, but with a much higher load limit?
steveastroukRocketPenguin
Answer 4 years ago
It would work, thought there are better chips from TI for example. You can use this pretty well with the other link you posted.
Answer 4 years ago
Mk, I'll just stick with this then, and will probably purchase the complete board with the chip already on it. Thanks!
