89Views3Replies
Author Options:
Dynamic ip to static? and is static needed to run a server? Answered
Hello I would like to know how I can change my dynamic ip into a static one and if I were to set up a home server how would I do that with out a static ip?
Tags:Servers
nofunclub
nofunclub
8 years ago
sign up with http://freedns.afraid.org
it is what it say,,  FREE
create a subdomain for freeor set up a domain you allready own
set up a dynamic DNS and install the client
then you must configure your routers port forwarding to the computer you use as a server ( set a fixed ip adress in your network setting )
get all that info at http://portforward.com/
works with all types of servers, even streaming media
msg me if you need to
Vyger
Vyger
8 years ago
Most ISP companies will give you a static IP if you need one but they often have a monthly charge for it. That is the best way to go although it might cost you a little extra.
frollard
frollard
8 years ago
Most home residential internet won't offer a static IP.
There are solutions around this: many domains and domain redirects offer client programs that dynamically update the online host to the new IP if it rotates. no-ip.com is one that uses a duc program. Without actively letting the domain server know where your server is, you can't easily run a server.
