302Views14Replies
Author Options:
E coli incubator Answered
I am building an incubator for ecoli.  Any comments or improvements?
rickharris
rickharris
2 years ago
WHY? Most people avoid Ecoli.
wesleysuhler
wesleysuhler
Reply 8 months ago
I'm a microbiologist. Nobody can avoid E.coli. It's a huge part of a healthy human microbiota. It's also probably the most studied organism in the world because you can literally grow a viable culture for whatever your research may be overnight, and observe results just about as fast.
avocadostains
avocadostains
2 years ago
It looks like it is arduino controlled, which is awesome, but beyond my understanding, so I can't help you there.
Is the incubator built yet? What are the temperature/light/humidity requirements of E. coli. Is it something where a simple temperature switch wired to a light bulb would be good enough? https://www.ebay.com/itm/2Pcs-10A-250V-KSD301-30-C... (Such as those) Also there are good DIY Sous Vide instructables that would provide more precise temp control, depending on which controller you buy, you can also control humidity levels. I'm sure you can do all that with Arduino too, but I wouldn't know where to start.
Also, I just kind of took a leap of faith and assumed you weren't a bioterrorist or something? Why exactly are you culturing E.coli? I had that before. It was gnarly, bloody diarhhea for 2 weeks or so.
drystreams
drystreams
Reply 2 years ago
Im not familiar with the temp switch and what ranges activate them. Ecoli incubation requires the ecoli to incubate at 35 degrees celcius (-+0.5). I take water quality samples to determine the health of streams. Thought it would be fun to build a cheap incubator.
avocadostains
avocadostains
Reply 2 years ago
Those temp switches, and I believe all bi-metallic temp switches are rated as accurate to about (-+2 degrees Celsius) . They are very precise. The problem that leads to that 2 degree or more swing lies with the controller and the heat source. The controllers are usually only programmable by integer degrees. So if you set an incubator set for 35C, the heat wouldn't kick on until the temperature dropped to 34C and it wouldn't kick off until 36C. Then, residual heat from your heat source can make the temperature rise even higher. To combat this, pick a heat source of appropriate wattage to the space you are trying to heat. Ideally you want the heat source to remain on as close to 100% of the time as possible. Shutting on and off contributes to the swing in temperature.
If arduino allows for fractional degree programming, like if you could set the value to 35.4C or 35.425C, I would be VERY interested to know. It may even make me consider learning arduino:) Hope this helps.
drystreams
drystreams
Reply 2 years ago
unfortunately +-2 degrees does not work.
I have it set for 34.9 degrees. When it kicks off, the heat sink allows the temp to climb to 35.2. when it cools down, the temp gets down to 34.7 (even though it kicks back on at 34.9). It is staying within the range I need. its a 100W 12VDC heater (large resistor). Its been working well for 4 days now.
avocadostains
avocadostains
Reply 2 years ago
Wow! That is impressive temp control. Definitely makes me want to learn more about arduino.
drystreams
drystreams
Reply 2 years ago
Arduino is pretty cool! Can do lots of stuff and there is a lot of code, tutorials and help in open source. Give it a shot!
avocadostains
avocadostains
Reply 2 years ago
I will! Thanks!
avocadostains
avocadostains
Reply 2 years ago
Nevermind. I just saw my answer. For water quality samples. Good enough for me. You're clear to fly.
drystreams
drystreams
2 years ago
The blue wire is the input to switch from NO to NC. But I see your point...just turning on the relay will do the job. I have had no issues with power (been running 3 days) but will incorporate capacitor. Curious if I needed any relays.
drystreams
drystreams
2 years ago
make better pets than chickens...
drystreams
drystreams
2 years ago
specifically do I need any resistors other than the one for the DHT22?
drystreams
drystreams
2 years ago
here is the diagram
