3330Views11Replies
Author Options:
Earth magnets vs Electromagnets ? Answered
If I have an earth magnet in my pocket but I want a more powerful magnet would an electromagnet be more stronger?? Thanks. AL.
kelseymh
kelseymh
Best Answer 9 years ago
That depends. A rare-earth magnet (note the name) has a fixed strength determined by the materials and manufacturing. An electromagnet's strength depends on how much power (current) you put through it, which is determined by a combination of it's manufacturing (specifically, the resistance of the coil) and the applied voltage.
So if you need a more powerful magnet than what you have now, you can either buy a larger (or differently made) permanent magnet, or a buy or make an electromagnet with a big, beefy power supply.
alsports2000
alsports2000
Answer 9 years ago
Thank you very much for taking the time to respond and your answer is very much appreciated. Thanks. AL.
lemonie
lemonie
Answer 9 years ago
Click a blue "Select as best answer" button.
L
steveastrouk
steveastrouk
Answer 9 years ago
It also depends on the saturation flux density of the core material.
Steve
kelseymh
kelseymh
Answer 9 years ago
Yes, indeed. Different core materials can produce substantially different field strengths for the same coil current. I felt that the fundamental difference for the OP, was the "tunability" of electro- vs. permanent magnets. The rest is engineering details (so spake the physicist :-).
Jack A Lopez
Jack A Lopez
Answer 9 years ago
Hey, uh, if y'all want some magnet porn, this link is good one: http://www.magnet.fsu.edu/mediacenter/features/meetthemagnets/index.html
I especially like their 36 T resistive (copper) magnet. No fancy-schmansy superconductors. No ferromagnetic core, because there is no ?known? ferromagnetic material that doesn't saturate well before about 2 tesla.
It just uses copper, and very large amounts of electric current, and also large amounts of fast moving cooling water.  According to this page,
http://www.magnet.fsu.edu/education/tutorials/magnetminute/bitterplate-transcript.html
the current through the helical winding is about 40 KA, and on this page
http://www.magnet.fsu.edu/mediacenter/features/meetthemagnets/35tesla.html
they say  the total power consumption is about 20 MW, and solving for R in P=I2*R, suggests the total resistance of the copper helix is only about 12.5 milliohm.
alsports2000
alsports2000
9 years ago
Also, the advantage of an earth magnet is that you don't have to deal with over heating. Thanks. AL.
steveastrouk
steveastrouk
9 years ago
Technically, yes, you CAN get stronger fields with an electromagnet.
The remanence of a rare earth magnet is failry high, at around 1.4 T, but an electromagnet can offer field strengths up to 1.6 T with a conventional magnetic material, 2 with some exotics.
State of the art, using fancy magnetic systems, which are completely unaffordable, is 30 T.
But you won't fit them, and their power supply in your pocket.
Steve
PS. State of the art is 1000T. But you have to blow the magnet up with explosives !
Arano
Arano
Answer 9 years ago
a few days ago i read that the world record is about 91 Tesla http://www.hzdr.de/db/Cms?pOid=33768&pNid=473 (in the upper right corner should be a button to change language if the page is displayed in german)
steveastrouk
steveastrouk
Answer 9 years ago
I can believe that, for a static magnet. Exploding coil magnets go an order of magnitude higher.
Steve
Arano
Arano
Answer 9 years ago
well its at least the strongest magnetic field where the coil does not destruct itself on usage...
