2748Views9Replies
Easiest method for magnetic levitation?
i have a ring magnet of about 4 cm diameter and additional magnet pieces. for my science project, i want to suspend one magnet in the air WITH OUT ANY SUPPORT. how can i do it? what are the factors affecting the stability? can anyone tell me the simplest way to perform that? what other shapes of magnet will i need to do that?
Best Answer 8 years ago
It is impossible to suspend one permanent magnet above another in any stable configuration without support. This is a consequence of Earnshaw's Theorem (which you can look up for yourself).
You can suspend a permanent magnet above a set of electromagnets, by using a feedback circuit to continuously adjust the electromagnets to "push back" the target.
You can suspend a sample of diamagnetic material (look it up) above a permanent magnet configuration.
You can "suspend" a pair of permanent magnet secured at the ends of a "C" shape above a fixed bar magnet, provided you include restraint against sideways motion. See Earnshaw's Theorem.
8 years ago
The answer depends much on what you consider easy.
I am going to guess that those levitation demos based on diamagnetic materials, like bismuth metal or pyrolytic graphite, are going to be the easiest method to give you a levitating magnet. Fortunately instructables exist for both those materials.
Here's a bismuth one:
https://www.instructables.com/id/Magnetic-Levitation-Sculpture/
Here's one that uses pyrolytic graphite:
https://www.instructables.com/id/Diamagnetic-Levitation-Experiment/
I think the spin stabilized magnet is going to be more tricky to get it to work. However there exists 'ible(s?) for that one too:
https://www.instructables.com/id/How-to-Build-a-Magnetic-Levitating-Top/
Answer 8 years ago
thank u...
8 years ago
You can use 4 fine threads to anchor the magnet and then your project can discuss Earnshaw's Theorem
8 years ago
Set a smaller magnet spinning over top of a larger magnet. Look at the instructables listed on the right.
Answer 8 years ago
is ther anyother way without spinning?? i mean keeping evrything stationary??
Answer 8 years ago
Not with permanent magnets. I'll write a longer description as a top-level answer.
Answer 8 years ago
how can we make a strong electro magnet?? about number of turns, diameter of cu wire, supply voltage etc etc...
Answer 8 years ago
Not without having something that keeps it from flying off to one side. Many mag-lev tricks involve a very thin wire to hold it in place. To get true magnetic levitation without support or spinning would be to use a superconductive material chilled with liquid nitrogen over a strong magnet.
