74Views0Replies
Author Options:
Electrical schematic help/wiring + arduino programming Answered
Hello,
first time user here, so i would like to just apologize for the wall of text that's coming up.
Im trying to build this little enclosure here https://www.instructables.com/id/Touch-sensitive-... and i have a hard time understanding the basics of the electronic schematic thats invovled, when he shows how to build it. Nor do i truly understand what components are in it, hence why i cannot determine the price of this build (based on electronics). So i was wondering if anyone could lable one component by one for me, aswell as how to connect them all together? so that i could calculate the pricing and see how much it would actually cost.
Seccond thing is that i wanted to change it up a bit, and use neopixels, or ws2812b led strips instead with a teensy 3.2 and fastled library code, for that fiery effect. Thought that might look really cool. However im concerned with the power draw of these ws2812b led strips. Getting information from adafruit: 60mah per led at maximum brightness, but thats eye blinding, so a 20mah per led is more logical, as someone with neopixels wouldnt be running full white anyways, and more colorful setup, or patterns. Im able to get 144 led/m quite cheap, but then the power draw of just 1m is a whopping 8.64 A. Which is starting to sound pretty dangerous at 5v. But then again, im not buying neopixels to run at full white brightness, i want the patterns. Im wondering if there is any possibilites to make a admin command or a priority list or something to lower the brightness of the strip entirely without messing up the code? i know regular leds have ir remotes to dim the light. I mainly just want the red flame effect, which is only 20mah at max brightness and a peacefull 2.88 A, but i also want white light + i want the safety of knowing i can supply the strip of the power it needs, just incase. The video with the code is underneath: (code in video desc)
and i know 144 leds/m is probably overkill, but then again, im getting them dirt cheap, + it would give off a much better fiery effect than a 60 leds/m or even a 30 leds/m
thanks in advance for any replies, and sorry for my wall of text. :)
