70Views12Replies
Author Options:
Electricity for the challenged Answered
I have a US plug AC/DC power adapter and need to get a European version. The specks on the adapter are input: 120VAC 60Hz 24 W and the output: 10 VDC 1400mA. I really don't have a clue as to what all these numbers mean but understand at a bare minimum I need something with a 10 VDC output. I've looked around at some shops and can find adapters that say 9v 1000mA and others that are 12v 1500mA. Do I need to get the exact voltage (I presume the v stands for volts)? What about the amperes ( I believe that mA is some increment of amperage)? Can I fudge the numbers a bit to save money and time instead of trying to get the exact configuration of the original adapter? Thanks for any help in clarifying this for me.
NachoMahma
NachoMahma
13 years ago
. You can get a 220-to-110VAC "travel converter" at most electronics stores. . . How exact you have to be when comparing specs depends on what the driven device is. For mechanical toys, &c, you can be off quite a bit without causing too much trouble. For computers and other "delicate" electronics, there's not as much wiggle room. . Match the volts as closely as possible and the mA should be equal to or slightly above the specs (have to disagree with Kiteman on this point - a underpowered brick is a fire hazard).
Crackpot
Crackpot
Reply 13 years ago
Normally on the adapters they say if they will take 120 through 240 VAC. The one I have is says only 120. I'd rather not plug the American adapter into a converter that gets bulky and hot not to mention wasteful. The adapter is for an Ipod clock radio that I bought in the states but want to use in Europe. Since it came with a power adapter I figured I could swap the us adapter for a EU one. I really appreciate your help with this. I've always gotten confused when trying to figure out electrical stuff. Just to reiterate a 9v and 1500mA should work? Thanks again
NachoMahma
NachoMahma
Reply 13 years ago
. Not sure about the V, but, if the cradle is USB compatible (ie, 5V), I'll bet a quarter it will work. A schematic for the cradle might help - if there is a 7805 chip (or possibly a 7905), that would be a good indicator that 9V could work.
NachoMahma
NachoMahma
Reply 13 years ago
. Have you tried contacting Jensen? Doesn't look like I'm gonna be much help and no one else has chimed in.
Crackpot
Crackpot
Reply 13 years ago
Actually you've been a big help. At least I have some understanding now of what the numbers mean and what I should be careful about. Thanks.
Kiteman
Kiteman
Reply 13 years ago
>!< I didn't know that. What's the reason?
trebuchet03
trebuchet03
Reply 13 years ago
Fire Hazard... I know first hand :p At least, there was smoke and upon dissection, the windings had fused and shorted out from excessive heat damage.
NachoMahma
NachoMahma
Reply 13 years ago
. If you pull 1400mA through a 1000mA brick, it will get very hot.
Kiteman
Kiteman
Reply 13 years ago
Are you sure? When I tried to run a 1200mA DVD player via a 700mA adaptor, all that happened was the DVD wouldn't run.
NachoMahma
NachoMahma
Reply 13 years ago
. That's possibly because you were pulling enough to shutdown the PS. Or maybe the DVD wasn't getting enough volts (PS pulled down below rated V). . Granted, it's not a good idea to have too much PS (primarily because of V regulation) - that's why I said "slightly above." . The 1400/100mA figures were just pulled out of the air. Point was that PSs that are putting out above their rating get hot.
Kiteman
Kiteman
13 years ago
What are you running? Check the instruction manual, it should tell you the tolerances.
If in doubt, though, go for an under-powered transformer rather than an over-powered one, to save the risk of damaging your device.
(yes, "mA" = "milliAmps" (1000mA = 1A))
