68Views3Replies
Author Options:
Electronics Answered
I am currently building an RC hovercraft, I plan to use a single 12 volt 2.1 amp hr lead acid battery to feed both the lift fan for the skirt and the power motor for the drive. However the fan for the skirt is 12v 0.3 amps. How can I reduce the feed to the required amperage with out affecting the other feed from the same battery that will power the drive
Seafarer77
Seafarer77
5 years ago
thanks guys, once completed I'll post pictures and video of hovercraft in action
Antzy Carmasaic
Antzy Carmasaic
5 years ago
The voltage should match. If the battery can supply more current, then that means you can connect more things or it will last longer for the same load. The fan will not draw more than 0.3 Amps.
verence
verence
5 years ago
Just connect them. It'll be fine. The fan needs 0.3A. The battery can supply 2.1A - that does not mean, it can send 2.1A into anything that is connected. Ta fan will take what it needs. So, the battery can feed 7 fans - or one fan and have 1.8A left over for other users.
