Elmers Glue substitute? Answered
105787Views11Replies
Author Options:
Hi, I have discovered a recipe for Kiddies Slime and it uses Elmers Glue. I have never seen it here. Can anyone advise what I can use as a substitute?
Tags:Elmers
steveastrouk
Best Answer 4 years ago
PVA wood glue.
Odettev1
4 years ago
Thank you all! You are awesome!
Stephane1588Odettev1
Answer 2 years ago
in case you are still struggling, bostik white glue
You're welcome
lukeutley_6
2 years ago
What is a good substitute for Elmers Glue?
rickharris
3 years ago
Your looking for any glue that says PVA on it. Essentially these are designed for Paper and wood gluing. You may also find PVA at a builders supplies - it is used to make plaster and cement more tacky.
Personally I buy a gallon jug of generic PVA glue it works fine with borax. Don't use too much or it goes very stiff.
kelseymh
4 years ago
First, you don't define "here," so you're pretty much on your own. Elmer's is a white glue; go to your local hardware store and ask.
Odettev1kelseymh
Answer 4 years ago
Here as in Pretoria, South Africa. Thank you. Will do.
NericaRrickharris
Answer 3 years ago
I've tried making 'Silly Putty' (same type of recipe and ingredients than Slime) with White Ponal Wood Glue, but it didn't work at all. Result was a hard rubbery substance, not putty. I will try out other types of white glue. I've researched a bit on substitutes for Elmer's glue in South Africa, but no luck yet (other than white PVA glue). Would LOVE it if someone found a brand which works well with Borax (it's apparently the PVA and Borax which reacts to make the polymer)
