4389Views9Replies
Author Options:
Epic Science Fair Ideas? Answered
I am not a big fan of doing a science fair project, but I would love to do something big and fun with minimal actual work. Does anyone have an idea?
Jack A Lopez
Best Answer 10 years ago
Um... how do you feel about ballistics? In simple terms, ballistics is the science of throwing heavy things and also figuring out where they're going to land. In general any hit-the-target kind of ballistics problem will involve:
(1) a projectile (the thing being thrown)
(2) an accelerator (some means of giving the projectile a controlled momentum, or equivalently some initial velocity)
(3) a target (some location where you want the projectile to arrive)
Obviously the particulars can be as complicated as you like. This class of problem includes everything from throwing a basketball at a hoop, to putting a lander onto the lunar surface, to dropping white phosphorous on innocent civies.
However, you specifically asked for simplicity, or "minimal actual work" as you phrased it, and I agree it's good to start with something simple, and get that to work before building a trebuchet and declaring war on the neighborhood.
One of the simplest (er most simple) physics-class ballistics demos I have ever seen looks like the illustration below.
The projectile, a steel ball bearing, starts its journey at point A. Then it rolls down the ramp AB, picking up m*g*h1 of kinetic energy by the time it reaches the bottom of the ramp. Note that some of this KE will be rotational, some translational. Then it rolls across the table, the horizontal path BC. At point C it takes flight and falls ballistically through the air until it reaches the target D, somewhere on the floor, which lies a vertical distance h2 below the surface of the table.
For the target you can use a bottle cap, or a pie pan, depending on how good your math is.
Obviously a bottle cap would be more impressive, since it's a smaller target.
The trick to predicting where the ball is going to land, as it moves ballistically from C to D, lies in treating the horizontal (x) and vertical (y) motions separately. Because the table top is horizontal, you expect the initial motion of the ball to also to be horizontal. Thus the vertical part of its velocity (vy) is zero initially. As a result the vertical motion is just free-fall.
vy= -gt with Tfall = (2*h2/g)1/2
and
vx= constant
x(Tfall) = vx*Tfall
where vx depends on the initial height of the ramp h1. The math for this is based on energy conservation. Expect 0.5*m*vx2 for the translational KE, while the rotational KE is a formula I don't recall at the moment. (Yet not too hard to figure out.)
Essentially you can control the position on the floor, vx*Tfall , where the ball hits, depending on what height h1 you start the ball on the ramp.
As mentioned before, this is a classic physics demo. So somewhere on the web there is probably a superior description of the same thing, compared to the one I've given here.
Kryptonite
10 years ago
Energy conservation or capture is always a winner, but a science fair project is best when it's original, so asking yourself what you're interested in, what you like or what you're curious about, and work off that.
science maniac21Kryptonite
Answer 9 years ago
I made a tesla coil and used it as artificial lightning for "is lightning a useful power source".
Jack A Lopez
10 years ago
Hey Aarobro! Thanks for choosing my answer as the "best", although I realize this may actually mean "least worst" out of everyone who bothered to answer.
Anyway, when describing this idea before, I sort of did some "hand waving" regarding the effects of rotational KE on the ball's speed vx after it falls through h1. For the sake of completeness, I thought I'd go ahead and explain that part for anyone interested.
The equation for the energy balance, from PE to KE, is:
m*g*h1 = KEtranslation + KErotation
m*g*h1 = (1/2)*m*vx2 + (1/2)*J*ω2
Radially symmetric objects, like rings, discs, balls, etc, rotating about their center, have moment of inertia of the form J = k*m*R2 where k is a dimensionless constant that depends on the shape (ring, disc, ball, etc). Also, vx=ω*R, since the object is rolling with its center R from the point where its edge touches the ramp. Substitute these into the energy balance equation to get:
m*g*h1 = (1/2)*m*vx2 *(1+k)
then
vx = (1/(1+ k))1/2 * (2*g*h1)1/2
where
k=0 for sliding (without rolling, like a wet ice cube)
k=2/5 for a rolling solid ball (like a ball bearing)
k=1/2 for a rolling disc (like a coin, or manhole cover)
k=1 for a rolling ring (like a ring, or section of pipe, soup can, etc)
These give adjustments to vx of {1, 0.845, 0.817, 0.707}, for sliding, rolling ball, rolling disc, rolling ring, respectively.
So if you had a "race" between a ring (0.707) and ball (0.845), you'd expect the ball to win, i.e. reach the bottom of the ramp first, and be moving faster when it did.
Source for moment of inertia formulas:
http://en.wikipedia.org/wiki/List_of_moments_of_inertia
swolleneyeball
10 years ago
Flame proof a cat. lol just kiding. blame everything2.com (just thought of it) Dry ice driven power. heck its got enough energy to explode mail boxes maybe it can be put to good use tesla tower?
Shredder543
10 years ago
I did batteries out of fruit and I won 1st at my school and 1st at regionals. If explained right it can prove to be a VERY successful project... hope it helps! =)
Re-design
10 years ago
Robots even simple one's that prove a point, energy oriented, health are all good areas that seem to do well and make interesting projects.
