Ethernet.h causing problems with 7 segment display driver [Arduino]
Hey Instructables,
I have a really annoying issue with some Arduino code I am writing.
The code is for an ethernet controlled countdown timer.
In it's component parts the functions all work fine,
I can drive the 7 segment display fine.
I can start/stop/set a count over Ethernet
However as soon as I add the line Ethernet.begin(mac, ip); in void setup()
The 7 segment display starts to show errors, specifically the first of the four digits. Even If I don't include any additional Ethernet related code in the loop, just calling the library on setup causes problems.
I'm not an especially experienced programmer so I'm really hoping someone can share a little of their wisdom here!
#include <elapsedMillis.h>
#include <SPI.h> // needed for Arduino versions later than 0018
#include <Ethernet.h>
#include <EthernetUdp.h> // UDP library from: bjoern@cs.stanford.edu 12/30/2008
int digit1 = 11; //PWM Display pin 1
int digit2 = 10; //PWM Display pin 2
int digit3 = 9; //PWM Display pin 6
int digit4 = 6; //PWM Display pin 8
//Pin mapping from Arduino to the ATmega DIP28 if you need it
//http://www.arduino.cc/en/Hacking/PinMapping
int segA = A1; //Display pin 14
int segB = 3; //Display pin 16
int segC = 4; //Display pin 13
int segD = 5; //Display pin 3
int segE = A0; //Display pin 5
int segF = 7; //Display pin 11
int segG = 8; //Display pin 15
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
IPAddress ip(192, 168, 1, 177);
unsigned int localPort = 8888; // local port to listen on
// buffers for receiving and sending data
char packetBuffer[UDP_TX_PACKET_MAX_SIZE]; //buffer to hold incoming packet,
char ReplyBuffer[] = "acknowledged"; // a string to send back
// An EthernetUDP instance to let us send and receive packets over UDP
EthernetUDP Udp;
elapsedMillis timeElapsed; //declare global if you don't want it reset every time loop runs
// milliseconds in a second
unsigned int interval = 1000;
unsigned int seconds = 0;
unsigned int state = 1;
unsigned int timeSetting = 10;
unsigned int oldSeconds = 0;
char theCount[9] = "01:06:30";
int secs = 0;
int mins = 0;
int hours = 0;
String isItTime = "";
String firstFour = "";
void setup() {
Udp.begin(localPort);
pinMode(segA, OUTPUT);
pinMode(segB, OUTPUT);
pinMode(segC, OUTPUT);
pinMode(segD, OUTPUT);
pinMode(segE, OUTPUT);
pinMode(segF, OUTPUT);
pinMode(segG, OUTPUT);
pinMode(digit1, OUTPUT);
pinMode(digit2, OUTPUT);
pinMode(digit3, OUTPUT);
pinMode(digit4, OUTPUT);
pinMode(13, OUTPUT);
void loop() {
displayNumber(millis()/1000);
void displayNumber(int toDisplay) {
#define DISPLAY_BRIGHTNESS 500
#define DIGIT_ON HIGH
#define DIGIT_OFF LOW
long beginTime = millis();
for(int digit = 4 ; digit > 0 ; digit--) {
//Turn on a digit for a short amount of time
switch(digit) {
case 1:
digitalWrite(digit1, DIGIT_ON);
break;
case 2:
digitalWrite(digit2, DIGIT_ON);
break;
case 3:
digitalWrite(digit3, DIGIT_ON);
break;
case 4:
digitalWrite(digit4, DIGIT_ON);
break;
//Turn on the right segments for this digit
lightNumber(toDisplay % 10);
toDisplay /= 10;
delayMicroseconds(DISPLAY_BRIGHTNESS); //Display this digit for a fraction of a second (between 1us and 5000us, 500 is pretty good)
//Turn off all segments
lightNumber(10);
//Turn off all digits
digitalWrite(digit1, DIGIT_OFF);
digitalWrite(digit2, DIGIT_OFF);
digitalWrite(digit3, DIGIT_OFF);
digitalWrite(digit4, DIGIT_OFF);
while( (millis() - beginTime) < 10) ; //Wait for 20ms to pass before we paint the display again
//Given a number, turns on those segments
//If number == 10, then turn off number
void lightNumber(int numberToDisplay) {
#define SEGMENT_ON LOW
#define SEGMENT_OFF HIGH
switch (numberToDisplay){
case 0:
digitalWrite(segA, SEGMENT_ON);
digitalWrite(segB, SEGMENT_ON);
digitalWrite(segC, SEGMENT_ON);
digitalWrite(segD, SEGMENT_ON);
digitalWrite(segE, SEGMENT_ON);
digitalWrite(segF, SEGMENT_ON);
digitalWrite(segG, SEGMENT_OFF);
break;
case 1:
digitalWrite(segA, SEGMENT_OFF);
digitalWrite(segD, SEGMENT_OFF);
digitalWrite(segE, SEGMENT_OFF);
digitalWrite(segF, SEGMENT_OFF);
break;
case 2:
digitalWrite(segC, SEGMENT_OFF);
digitalWrite(segG, SEGMENT_ON);
break;
case 3:
break;
case 4:
break;
case 5:
digitalWrite(segB, SEGMENT_OFF);
break;
case 6:
break;
case 7:
break;
case 8:
break;
case 9:
break;
case 10:
break;
5 years ago
Rewire it so the display isn't using pins 1 and 2. ! and 2 are the transmit and receive pins the Arduino is using to communicate between the micro and the Ethernet shield/chip. Double check the library and see what pins it's expecting to use for it's various functions.
Reply 5 years ago
Dude, thank you so much for your reply! This was indeed the problem..
EXCEPT!
The pins that were causing me problems weren't 1 and 2, but 10, 11, 12. Premis was correct though! Thanks
