90Views1Replies
Author Options:
Excercise car? Answered
What I am designing (and planning on working on very soon) is a vehicle with the possible speed of a gokart, but with a propulsion system similar to a bike.
The mechanism itself would be a simple push pedal (like a car) but with a gear system like a bicycle. Upon pushing down the pedal, a shaft connected too it would then push against the foremost gear. and that gear would push another and so on until it comes in contact with the rear wheel, propelling it forward. A simple spring between the pedal and floor will allow the pedal to return to the original position.
However I cannot seem to get the steering and brake system down right. Should the steering be that of a car and use 2 wheels on the front with a long axel connecting the 2? or more like a bike, with a one wheel turning system. (aka. should it be a 4 wheel or 3 wheel?
Might depend on weight distribution and balance, though both could be possible.) and how should the brakes be arranged? a pedal, like a normal car brake, or a stick beside the driver, like an emergency break, as well as where the brake pad would come into contact with the rear. On the axel or on the wheels?
Last (and most definitely not the least) is that while this vehicle must be sturdy, it must also be light weight. So any and all material recommendations for parts would be greatly appreciated. (cheap would also be appreciated)
(My thought for material)
chasis - light, but firm (strong) wood.
axels - aluminum or steel
tires - Gokart/ riding lawn mower
turning wheel/steering - wood or plastic
seat - whatever I can find that's soft (not a major thing)
safty belt - I may not be able to test out the prototype (kinda thick) so I need the crash test dum *ahem* "driver" to survive incase a crash were to happen.
brake pad - rubber so that it causes the right amount of friction but not enough to damage any parts.
caitlinsdad
caitlinsdad
7 years ago
Look up tricycles, trike, recumbent bikes, surreys, pedocab taxis. Gokart designs can be modified to be powered by pedal. Good luck.
