101Views6Replies
Author Options:
Find the inner diameter of the pipe whose inner diameter is varing in the range 0.5cm to 8cm? Answered
i need to measure the inner diameter of the pipe the range of the inner diameter is 0.5 cm to 8 cm . what should i use ?
laser ? or I.R sensors or anything else that  you can suggest ?
crazyg
crazyg
5 years ago
fill it with water.
measure the volume of water in cl.
divide that by the length in cm.
divide that by 3.14
average diameter
or
measure the outside diameter minus twice the material thickness.
or long nose vernier caliper.
thakkarjinal99
thakkarjinal99
5 years ago
I meant the inner diameter not the conical profile
Accuracy upto 2/3 decimal places
steveastrouk
steveastrouk
Answer 5 years ago
Decimal places is precision, accuracy is how close to the real value you want.
Unless you aren't telling us something else, then a digital caliper is probably good enough. If you're worried by out of round errors, take several readings of diameter and then average them.
rickharris
rickharris
Answer 5 years ago
Man who puts 5 shots in a 1 inch circle on the edge of a target is very precise.
Man who gets 5 shots in the Bulls eye is very accurate!.
A variation of 0.5 cm to 8 cm is pretty rough manufacturing if the diamater vairies that much.
steveastrouk
steveastrouk
5 years ago
Do you mean its a conical profile, or it may range in internal diameter from 0.5 to 8cm ? How accurately and precisely do you want to know ?
