1166Views2Replies
Finding an appropriate heatsink for 5V 3W LED?
Hello, I have bought some 3W 5V leds, and now I have to dissipate the heat they produce. I am thinking of using an xbox 360 GPU heatsink i have laying around (
https://s3.amazonaws.com/assets.overclock.net/7/7b/7bb1229a_vbattach111891.jpeg
), cut in apprpriate size. Then I would glue the led with thermal epoxy to it.
Can somebody suggest an adequate size for the heatsink? I can't find any info around. I have other heatsinks as well, I would rather not buying a LED heatsink if that's not mandatory.
Thanks in advance :)
Picture of the leds attached, they have no board to screw them with.
Best Answer 6 years ago
I'd not glue them on, I'd use screws and heatsink compound. The cooler you keep the LEDs the longer they'll live.
Answer 6 years ago
Do you think thermal compound is not enough to ensure a good heat transfer? I can' use screws, the leds are without board.
http://i.ebayimg.com/00/s/OTQwWDk0MA==/z/Y2gAAMXQVT9SzLhM/$_12.JPG
Answer 6 years ago
I've had good success with these things mounting them on 30x 30mm PCB squares, with a little thermal compound under them
Answer 6 years ago
What kind of PCB did you use? The star-like most high-end Cree leds use?
Answer 6 years ago
The crees are using aluminium substrate material, which isn't easy to get as an amateur. I just used plain FR4 for these little LEDs. If you're making real boards, then you can put a load of vias through around the LED into the layer on the back, and get improved cooling performance.
Answer 6 years ago
All right, ordinary boards seem just the right way to go. So I can just use a spare circuit board with some thermal paste under the LED, right? Thank you for all the help!
Answer 6 years ago
Do you think that just the PCB is enough to keep it cool? I don't think so but I assume I would able to screw the pcb on the heatsink then.
