642Views1Replies
Author Options:
First solar project. How do i connect a small solar panel to a batter to then supply power for a outlet? Answered
So this is my first time taking a dip into small electrical work. I would like to take a small solar panel and use it to charge a small battery that could supply 5 watts of power for about 4-5 hrs through a standard outlet plug. what would i need to do so and any other guidance would be appreciated.
frollard
frollard
11 years ago
The others say its impractical, but its not THAT impractical. To put out 5 watts for 5 hours, considering losses you want at least 10 watts of input for at least 5 hours. (arbitrary) Get panels that output 12 volts for a car battery (most common), then you can run a small digital AC inverter to created the wall-socket power you need for x (presumably charger).
rickharris
rickharris
11 years ago
Your plan is impracticable. Your battery won't give the same voltage as the normal wall socket AND will be DC not AC You would/will need a BIG solar panel to keep the battery supplied with top up electricity and a LOT of sun Shine. There is a good reason why domestic Solar power is almost unknown, and why it is expensive.
