703Views6Replies
Author Options:
Flat pack / interlocking design question Answered
I'm trying to make a flat pack interlocking chair but cannot figure out how to get the bottom pieces from falling out when right side up.  If I want the chair to have a uniform square shape, I don't think I can make the locking cuts at any angle.....so, the bottom keeps falling down.
Below are two examples of interlocking that confuse me.  The first is a link to the table upside down.  The second is a link to the table right side up.....Can someone please explain how the long pieces which are in the "under" position of the lock do not fall out when turned right side up?
http://www.ryandartdesign.com/work.cfm?listPos=11
http://www.ryandartdesign.com/work.cfm?listPos=10
Thanks!?
Chasingthesun73
Chasingthesun73
9 years ago
Thank you all for your help. Great suggestions....and good eye Rick- I never would have caught that!
rickharris
rickharris
9 years ago
The 5th leg back and I guess the same at the other end appears to be put in from the bottom holding the long rails in place when the assembly is turned over and weight is applied. The rails merely act to separate the leg segments and support those not touching the ground..
canucksgirl
canucksgirl
9 years ago
I agree with Steve. Other than tight joints or using glue, it does appear as though the intersecting pieces (to the series of "U" shaped pieces) would fall out. The only other option would be to make the cuts to the long pieces on the opposing side so that they connect from the top versus the bottom. (I'm assuming your cutting the pieces?)
steveastrouk
steveastrouk
9 years ago
Tight joints ?
Glue ?
You could deliberately slightly angle the slots in opposite directions on each piece, automatically making the joint tight as you drive the cross member in. It might be barely perceptible.
CameronSS
CameronSS
Answer 9 years ago
A similar method I've seen is to put a "nub" on the inside of the slot, which makes a tiny section of the slot narrower than the thickness. Pound the pieces together for a tight fit.
steveastrouk
steveastrouk
Answer 9 years ago
Yes, that would work too.
