122Views6Replies
Author Options:
Fluctuating voltage? Answered
I am trying to build an ammeter using a 100:5A CT and a pic16F716 and display the value using 7segments. However, The voltage I get from the CT after rectifying it using an OPAMP still fluctuates between 4.8 and 5.4 .  I don't understand what is causing it to fluctuate that way. I will attach a picture of the circuit I am working on.
steveastrouk
steveastrouk
4 years ago
A very nicely developed circuit Indira, you've really listened to what people have suggested, which is pleasing to see.
I suggest you have some other source of noise. Have you got an oscilloscope to look at the output on C2 in your diagram ?
IndiraK2
IndiraK2
Answer 4 years ago
I added a simulation using the oscilloscope. The yellow represents the input current while the blue almost straight line is the output from C2.
steveastrouk
steveastrouk
Answer 4 years ago
Have you built this, or are you working purely in a simulation. The blue trace of the final signal looks beautiful, and what you should expect.
IndiraK2
IndiraK2
Answer 4 years ago
I have built it and actually testing how it works. However coding has never been my forte so I tried using parsic to create the code. Still the last 7 segment doesn't light up.
steveastrouk
steveastrouk
Answer 4 years ago
Get it to output the measured current to the serial port first, before you worry about the display. Lets see if the real data is noisy.
iceng
iceng
Answer 4 years ago
+1
