8892Views7Replies
Author Options:
Food Saver Model V3835 won't open for cleaning? Answered
I was trying to seal a food bag and the vacuum wasn't working so I decided to clean the tray that collects moisture. However after pressing the 2 release buttons the food saver wouldn't open up for cleaning. I have been unable to find what is holding the unit closed. I removed the bottom cover and found the right hold down gear/"hold down" paw not engaged. I re-engaged the paw but still can't open the unit.
SealerUser
SealerUser
1 year ago
I have the V3835. I see online several places to reorder gaskets, but when i open my machine up, it says my gaskets are not removable? I am having an issue with it not completing the vacuum cycle before sealing. Help?
LauraS16
LauraS16
1 year ago
My Food Saver would not open today after I sealed cheese. I unplugged it then plugged it in again and pressed the seal again then cancel after a few seconds. Worked like a charm. Not to say I wasn't in panic mode. Terrified that my 1 yr old Food Saver was ruined. I use it practically every single day... mostly the canisters and marinade container.
gmark
gmark
2 years ago
On some models, there is a safety latch, inaccessible from outside the machine, than can prevent access. This has happened to me when a cycle was interrupted by unplugging it before it had finished. To clear this safety, simply replug in the machine, then, select "cancel". After this, simply use the side buttons as you normally would.
BethM167
BethM167
Reply 1 year ago
Thank you, gmark, your suggestion worked like a charm. I'm glad I didn't force it open and break it! ☺️👍
RonR93
RonR93
3 years ago
Wow tapping on the sides worked for me. Thanks for the advice.
Downunder35m
Downunder35m
5 years ago
There are only the side latches holding the lid, but in most cases they only disengage if you press the lid down!
They should pop out then but sometimes they can get stuck due to a lack of cleaning and stuff going into the mechanics.
In that case it helps to tap them while pressing the lid down, use the finger, knife handle...
No force is require to open the lid once the latches are open and on some models you can press the bottom of the latch to help it open (while still pressing down the lid!).
Jack A Lopez
Jack A Lopez
5 years ago
It seems like this forum gets a fair amount of questions about FoodSaver(r) brand vacuum sealers, e.g.
https://www.instructables.com/tag/type-question/?so...
I don't think Instructables Answers is all that good at actually answering these questions. In the list I've linked to there, only like 1 out of 10 was marked as "answered"
However, there are other places discussing FoodSaver(r) problems. I know Youtube is one of these places,
https://www.youtube.com/results?search_query=foods...
and of course you should check to see if Google(r) has picked up any chatter on this topic, e.g. "foodsaver stuck"
https://www.google.com/?gws_rd=ssl#q=foodsaver+stu...
Final note: I think the word "pawl" has "L" on the end when it is part of a machine, and it is just "paw", without the "L", when it is part of a dog or cat.
Sorry I don't have any better answers than these, but I am hopeful that if you persevere, you will get your food vacuum bagger working again.
