408Views10Replies
Frequency of 12v halogen transfomer?
Hello everyone..
I would try using a 12v transformer halogen (please see photo) for flyback driver (about 10-30 watts) .But seller sell on Ebay do not know the frequency of 12 vac, so could you help me to know that(frequency of 12 vac out) thank you in advance.
6 years ago
If its an electronic transformer, it might not be mains frequency. What do you want to do with it ?
Answer 6 years ago
Dear steveastrouk
Best regards
lam
Answer 6 years ago
Let me see your intended circuit.
Answer 6 years ago
Dear steastrouk
Please see at:
http://www.loneoceans.com/labs/flyback/
and photo (but I will to buy 120vac not 230ac as picture)
Thank you so much
Answer 6 years ago
That won't work as a flyback driver without more electronics.
Answer 5 years ago
check the output waveform, it's a high frequency which can drive a flyback.
Answer 6 years ago
Dear steveastrouk
Thank you alot for your advice
Best regards
6 years ago
If it's 50Hz or 60Hz going in then it will be 50Hz or 60Hz coming out.
Answer 5 years ago
no, because smpsu's use pulse-width modulation,and therefore output a high frequency, instead of a normal transformer, in which the output frequency is the same as the input frequency.
5 years ago
I ripped one of those apart, definatly an switch mode power supply-so it'll work for your flyback driver.
