110Views6Replies
Author Options:
Fungus problem? Answered
I have a small 5 gallon aquarium in a cupboard and there is fungus all around the wood in the cupboard! How do I stop this fungus from growing there. I also have a big aquarium for almost 5 years now whose hood is always very damp, but never had fungus on it. Anyone knows why this is happening with the small one?(And there is no difference in placing. They are both side by side)
Josehf Murchison
Josehf Murchison
Best Answer 6 years ago
Don't use bleach, just use a good soap and water.
Then paint with a good mold and fungus retardant paint.
Last air flow, moisture from the tank is being trapped in the cupboard you need air flow to take the moisture away.
Ahtasham Ahmad Mohtashim
Answer 6 years ago
couldn' t find a fungus retardent paint. Will an extra coating of ordinary paint work?
Josehf Murchison
Josehf Murchison
Answer 6 years ago
If you wash it well and make sure the wood is dry before you paint and you use oil based paint it may last for a while.
rickharris
rickharris
Answer 6 years ago
You should find suitable paint in the bathroom and Kitchen paint area.
Vyger
Vyger
6 years ago
Plus 1 on the bleach. BUT be careful to use the correct dilution. If your solution is to strong it can destroy the paint and the fumes can get into the water. So a mild solution just strong enough to sterilse. You may have to repeat it on a regualr basis.
mpilchfamily
mpilchfamily
6 years ago
The fungus was probably aready there on the wood or paper. It's only had a chance to grow now that there is a good amount of moisture from the tank. Keep the cupboard well light. Clean it out with bleach and you'll kill what's already there.
