689Views19Replies
Author Options:
GBA sp ribbon pins: What does these do???????? Answered
I know the ribbon pins of the GBA sp AGS-101 backlit screen,(there are 34 pins total) and I want to hook up the pins to a vga cable to connect to the tv/monitor, (and I know how to connect the audio, that's not a problem) but the problem is, I don't know what these pins are, or do? Please help, there is a picture of a vga diagram.( I am trying to make a GBA sp Console)
1 - VSHD
2 - DCK
3 - LP
4 - PS
5 - VSHD
6 - GND
7 - LDR5
8 - LDR4
9 - LDR3
10 - LDR2
11 - LDR1
12 - LDG5
13 - LDG4
14 - LDG3
15 - LDG2
16 - LDG1
17 - GND
18 - LDB5
19 - LDB4
20 - LDB3
21 - LDB2
22 - LDB1
23 - SPL
24 - CLS
25 - SPS
26 - MOD
27 - REVC
28 - P2-VDD
29 - P2-VSS
30 - COM
31 - VDD5
32 - GND
33 - ??? (U83 on AGS-001)
34 - VDD5
8BITR
8BITR
Answer 4 years ago
I need the Gameboy advance sp
rickharris
rickharris
Answer 4 years ago
So look for it. Google is your friend.
Josehf Murchison
Josehf Murchison
4 years ago
VSS + volts
VDD - volts
GND ground
COM common
Common and Ground are not the same.
LDR, LDG, LDB data inputs
The others you need the datasheet they can be fixed high, fixed low and clock.
8BITR
8BITR
Answer 4 years ago
ok, thanks, so these are the only ones I need, for video?
Josehf Murchison
Josehf Murchison
Answer 4 years ago
You may need a driver to split up the color inputs, I'm not sure if a SN74LS595 would work.
8BITR
8BITR
Answer 4 years ago
where could I get my hands on SN74LS595 if it would work?
Josehf Murchison
Josehf Murchison
Answer 4 years ago
I buy a lot of components from Mouser they are very good for components and datasheets, I got 100 transistors from them for the same price as 5 from Radio Shack.
I just checked with Mouser SN74LS595 are $15.00 each but SN74HC595 (The same IC.) are only $0.75 each. It is the best price I could find on the net. If memory serves me right sales over $25.00 free delivery by mail.
http://ca.mouser.com/Electronic-Components/
8BITR
8BITR
4 years ago
Been going about it the wrong way, make a smallish computer, that can handle GBA games or any old games like gb, and make my own operating system using Linux to make it look more like a console, and design the case to look like a console to, so just emulate the games, perfect! Inspired by: http://www.lakka.tv
8BITR
8BITR
4 years ago
sorry, what? and the model of the dvd player that I was going to use is "Sylvania SDVD1650", that's the one I was going to use the driver from to connect the GBA sp to the tv, please help.
Downunder35m
Downunder35m
4 years ago
I doubt it is possible as most displays require a driver board.
8BITR
8BITR
Answer 4 years ago
oh, so like the GBA tv converter? I don't, and can't get that, but I have a dvd player I don't use, with component and composite, so could I take out the converter withen the dvd player and use that, or? Because I really want to do this for the GBA sp.
Downunder35m
Downunder35m
Answer 4 years ago
What I was trying to say is:
Every naked display needs a driver that converts the incoming signal to something that works with the display.
So would need to find a driver board for your particular display that offers the video or VGA inputs you need.
Might be a good idea to check some GBA forums that do modding...
8BITR
8BITR
Answer 4 years ago
so, can I use a dvd video driver board? Because I have one that works, but I don't use it, but it has component and composite, so can I use that?
Downunder35m
Downunder35m
Answer 4 years ago
Sure you can if it has the right connection for your display....
8BITR
8BITR
Answer 4 years ago
so, then can I take a picture of it then, and then u see if I can use it or not?
Downunder35m
Downunder35m
Answer 4 years ago
I already said you need a controller that works with your display and has the connections you need.
If you can't tell your controller is the right one than I can only tell you it won't work.
Rick already showed you a diagram, do some research, check GBA forums and then you will see if someone has done it and what is required, otherwise it is a bin case.
8BITR
8BITR
Answer 4 years ago
yeah, but the diagram is of the gameboy, not the advance sp, which I want to know what th pins does, so I can hook it up to a driver board, or at least the ones for power of LCD and the video, so I can hook it up to composite or VGA, either one will do.
8BITR
8BITR
Answer 4 years ago
and do you know what each pin does? and would u know how to hook up to the converter(if I give u a picture of it)that's if yes, if that's what I need
