GY6 50 cc chinese scooter won't start. What could it be?
Hi.
I bought a 50 cc scooter that was sitting for some time. It's 2008 model and it had around 400 km when I got it. That's pretty low in my opinion. Well at first it was running fine. I mad around 100 km on the first day.
Well the second day it didn't start. Thankfully my friend helped me and he said that my carburetor is dirty. He celaned it and scooter started up. I made around 60km on the same day with no problem.
In the morning the next day my scooter wouldn't start. I tried to do the same as him. I cleaned carburetor and fuel filter but scooter still wouldn't start. It doesn't start electrically or kick start.
It's like 5th day and my scooter still won't start.
What happens when i turn it on:
- sometimes it sounds just like a dc motor spinning but nothing happens (there is no cranking sound)
- usually it makes cranking sounds but doesn't start
- when I let it sit for a while (for 30min, 1h, day ...) it makes a sound like it almost started up but then dies
Thank you all for help!
I would like to apologize for my lack of english words in engines and bikes field (not a native english speaker and I'm not specialized in those fields).
4 years ago
Tick these off as you eliminate them:
No fuel to carb.
No fuel through carb
No spark
Spark at wrong time
Answer 4 years ago
1. Fuel goes to carb. Triple checked
2. I am not sure how to check that.
3. Checked it twice and even got a new sparkplug.
4. Not sure how to check that. Unadjusted valves?
Answer 4 years ago
For 2 you may just have to blow through all the jets. It depends on the type of carb.
Answer 4 years ago
Thanks dude that worked :D I cleaned carb 3 times but I didn't know how clean those jets have to be. So 1 jet was indeed stuck. Fixed it with sewing needle.
Thanks again for all the help
Answer 4 years ago
For 4 check the timing if it is adjustable. Spark should be at or just after top dead centre of the piston.
Answer 4 years ago
I would add after everything else is eliminated:
Low compression
Leaking cylinder head gasket.
Too much air in the mixture - usually a leak.
Answer 4 years ago
It could be one of this three because i once put my hand over air intake while trying to start it. It actually started that way. I got less air to engine.
Answer 4 years ago
Looks like you may have answered you own question. Weak mixture may be caused by a blocked jet as well.
Answer 4 years ago
Yeah but i have cleaned really good. I let it soaked it 100% alcohol for 10 mins and cleaned it with petrol. I also blowed thru them. I have 2 questions.
1. Is there a way I could clean them better?
2. What should be position of air-fuel mixture screw?
Thanks for everything so far.
1 year ago
I have a yamaha vino 50. I was sitting at a stop light and it died.it hasn't started since.it has strong spark and the fuel pump is good.what else could be the problem
2 years ago
In 2018, purchased a 2008 50cc scooter from a college kid. Poor thing was abused. Left out in the rain/snow. Dropped several times. Had 1,000 miles on it. Got it running with a friends help. Used it Summer/Fall 2018. September had a rough start before going to work. Got to work but couldn't start to go home. Scooter sat inside over winter. Trying to get ready for 2019 riding season.
Still can't start.
Things I've done in troubleshooting.
1. Installed new spark plug.
2. Added fresh, premium gas to boost last year's gas left in tank.
3. Replaced carburetor.
4. Battery still sounds like good cranking strength. Checked for proper voltage. Good.
5. Checked for gas flow. Manually sucked on vacuum hose to check gas petcock diaphragm. Yes, it allows gas to flow.
6. Disconnected gas line downstream from filter. Pushed the start button to crank cylinder. Good gas flow post-filter.
7. Pulled spark plug to see if gas is getting to cylinder. Spark plug tip appears to be dry.
Questions of the Day
1. Why am I not getting gas thru the carb to the cylinder head?
2. It's a brand new carb! Vacuum line was attached to the cylinder intake elbow. Do I have to do anything else other than attach the fuel line? Do I have to open the carb drain line to bleed out air from the new carb? Is the design of the carb one such all one has to do is attach the fuel line and you're good to go?
3. Could the enricher be a problem? The carb came with one$ attached so the assumption the enricher is brand new, also.
Please help! I'm at wits-end! I'm an amateur but just can't figure this out. I don't want to go to a repair shop just for them to tweak something and charge $100.
Thanks for the support!
EllEss2929
4 years ago
Is there a "choke" on this motor? If so, a cold start often requires the choke to be engaged to restrict air flow during warm up. If it uses an automatic choke, it may be gummed up or otherwise isn't operating as designed..
Answer 4 years ago
Thanks for help :)
I gess i was really sloppy when cleaning carb. 1 of the jets wasnt clear enough. Cleaned it with sewing needle and my scooter works again :D so happy
Answer 4 years ago
Your welcome!
