3697Views5Replies
Gas engine tachometer phone app?
Does anyone know of a tachometer app for a phone or PC that can estimate gas engine rpm by sound? One would enter options like 2-stroke or 4-stroke and number of cylinders, then hit the analyze sound button. I found one for RC helicopter rotors but couldn't find anything else.
10 years ago
Found it.
http://itunes.apple.com/us/app/engine-rpm/id340401811?mt=8%20(http://itunes.apple.com/us/app/engine-rpm/id340401811?mt=8)
10 years ago
That's going to be an interesting little challenge. There are a lot of parts in a gas engine, spinning at many different speeds, so there's a lot of noise to sift through to find the frequencies you're interested in. Might be easiest if you took your recording at the exhaust; there will still be a lot of noise but the firing frequency should be the strongest.
My first-guess approach would probably be to convolution-filter down to the frequency range you're actually interested in, then (if that isn't clean enough to just count peaks per second) run that through FFT to get a frequency graph and report the strongest frequency or frequencies.
As far as whether such a thing already exists: I'd have to websearch, and you can do that as well as I can.
Answer 10 years ago
I was thinking of recording at the exhaust as well, should be the most consistent rhythm to record.
Answer 10 years ago
. If the muffler isn't "too good" you should be able to count the pulses at the exhaust without all the fancy filtering.
. It might be possible to replace the photodetector on an optical tach with a microphone, but, as orksecurity points out, you can probably find what you want (schematic and/or finished product) on the Web. I'd start by searching for "acoustic tachometer", "audio tachometer", or similar.
Answer 10 years ago
Thanks for the tips, I'm still searching.
