56Views3Replies
Gear 5 Slip out problem while driving?
I'm driving VW Citi Golf and when driving and change to 5 gear it slip out,can this be caused by low gear oil?
4 years ago
If you are very luvky it is your stick itself.
There is a control plate and spring included, once out of alignment/worn they tend to cause trouble.
Onve the vocers are removed you should see the problem, if not take it to a good mechanic.
4 years ago
Most of the time that is caused by loose linkage.
Surprisingly it is a common problem, just needs adjusting.
Real simple fix.
4 years ago
This is a garage / mechanic job. %th gear often has a detent spring to hold it in place this may be broken.
Or there may be something wrong with the gear box.
