83Views1Replies
Author Options:
Is there a common standard for mounting servos to other things? Answered
For exmple - is there a standard bolt pattern or splined post that you have to consider when working with a servo or does it vary?
Thank you!
AndyGadget
Best Answer 8 years ago
Normal RC servos usually come with an assortment of fittings which usually include a 4 armed piece, a 2 armed piece and a holed disc. THIS is a standard assortment.  These are usually nylon / plastic, bur may be metal or karbonite on more expensive or larger servos.
The splined fitting varies from manufacturer to manufacturer, and from servo to servo depending on size, but the vast majority of servos you buy will include suitable ones.
