460Views6Replies
Author Options:
Getting a broken screw out of mdf? Answered
Okay I have this problem with a screw being stuck.
It's a small screw size, like maybe #10, but can't tell. It's stuck in 3/4 inch mdf, and it goes through the mdf. I've tried everything to get it out. Pliers don't work, and I absolutely CAN NOT drill out a larger hole.
I tried super gluing a nut to it (yes, I know, stupid idea) didn't work.
Only other idea I have is possibly welding a nut onto it, but I have no access to any kind of welder. I can get a butane torch with interchangeable 'soldering' tips, but I think I could possibly do a cheap tack weld that way if it gets hot enough.
Other than that, does anyone have any ideas on what I can do? I'd like to preserve the threads as I will be using the same hole.
rickharris
rickharris
6 years ago
If you use heat you will burn the MDF and perhaps spoil it.
Your best bet is drill a suitable size hole in the head and then:
use an easy out.
Use a left handed drill of a suitable size.
Force a length of rod in the hold and remove with pliers or similer
xander.zoolander
xander.zoolander
Answer 6 years ago
It has no head, the head broke off.
rickharris
rickharris
Answer 6 years ago
You can still drill down the shank.
In most case a second screw will just go down the side of the original and give a firm hold anyway if the head has sheared off.
Burf
Burf
6 years ago
Based on the criteria you've set, the only thing I can think of that will work is a "hollow screw extractor." The extractor will bore a dimensioned hole (1/4", 5/16" or 3/8") around the broken screw and grip the broken screw and extract it, ( the extractor is left handed.) You can then fill the hole with a dowel of the appropriate size.
I got my extractor set some years ago from Rockler hardware.
xander.zoolander
xander.zoolander
Answer 6 years ago
I can't bore a hole out. I need to replace the broken screw (which it has no head) with a non-broken screw, and I'm afraid boring out the hole and plugging it with a dowel won't work because of vibrations.
Burf
Burf
Answer 6 years ago
Then the only other way I can think of is to gently chip away the wood around the broken screw until enough is exposed to get a grip on it with long nose Vise Grip ( locking) pliers and back the screw out.
