80Views1Replies
Author Options:
Grommets for 10mm hole in glass bottles? Answered
I drilled a 10mm hole in my bottle for lamp cord and need grommets to protectect lamp cord. Where can i find grommets like these?
Paige Russell
Best Answer 2 years ago
Hi Richly,
A plastic bushing should work nicely. This one from Grand Brass will be just a tad bit smaller than your 10mm hole, allowing room for adhesive:
https://www.grandbrass.com/item/bg200w/bushings_an...
This one may also work:
https://www.grandbrass.com/item/bg1%2F4i/bushings_...
Alternatively, you can slide a small piece of this protective fiberglass wire sleeve (see link below) up the lamp cord until it covers the section that goes through the hole. This will adequately protect the cord from the sharp glass edges:
https://www.grandbrass.com/item/tofs6mmw/wire-wire...
I hope one of these will work for you!
Best,
Paige
