182Views4Replies
Guitar String as Record Stylus?
I'm wondering if you can use the high e (smallest one) guitar string as a record stylus, because I lost the stylus I have. I cant find one anywhere and they're too expensive online. I've tried it on an old record, but the sound is kind of distorted (the pitch keeps fluctuating). Will it harm any records?
Best Answer 9 years ago
Don't do it, it will knack-up the record's.
Buy a 2nd-hand turntable, or see what you can find on eBay.
L
9 years ago
Don't do it. You'll end up destroying your vinyl. Instead, try MCMElectronics and look for the original. They have many styli priced from $1.19 USD to $159.00 USD. You and your vinyl will thank you.
Qa
9 years ago
You might/would be better off with a steel pin or the end of a sewing needle. BUT modern records made from Vinyl are much softer than old time shellac or phenolic records (eg 78's) so will damage easily.
9 years ago
Don't use a guitar string; it'll just wobble around hardly following the grooves, and will probably scratch the record.
