88Views6Replies
HDI move an object with electricity 1/4 to 1/2 inch
If I need to move a small object with electricity how would I do this and what would I need? Thanks in advance.
6 years ago
Okay, I want to move six objects 1/4 in. in diameter by 1inch long(known as a pin) a distance of 1/2 in. The pin is spring loaded and needs to be moved downward to unhook it so that it can move freely. All need to move in tandem. Hope that is enough detail
Reply 6 years ago
Use an electromagnet or dedicated electromagnetical puller (basically just a coil whers the pin is "sucked" into when the coil is energised.
Reply 6 years ago
Thank you.
6 years ago
Some use motors, other magnets or even coil guns.
If you want a specifc answer ask a specific question first ;)
6 years ago
Depends on the object, budget, skill level and available supplies.
6 years ago
Rub a balloon on your hair, then hold it over a scrap of paper. Presto!
