302Views21Replies
Author Options:
HELP, i need to reinstall windows to my computer! I installed linux then, ALL my files and windows vista have been lost! Answered
HELP i need to reinstall windows and ALL my files back on my computer!!! I installed Linux but that is the only OS i can run... while rebooting, it wont give me the choice of running windows vista!
i didn't back up anything as i was lazy and didn't want to get a secondary hard-drive.
can i at least recover all my files? how do i recover windows without a CD?
Burf
Burf
9 years ago
If you didn't (or didn't tell the Linux installer) partition your hard disk, then all your Windows files are gone.
If the disk was partitioned, then you may need to re-install the Grub boot loader so that the Windows partition is recognised.
Which version of Linux did you install?
-max-
-max-
Answer 9 years ago
linux mint 10 (or 9)
-max-
-max-
Answer 9 years ago
i dont remember if i "partitioned" my computer. how do i "re-install grub boot loader"? i would like both Linux mint and windows both on my computer. when i first downloaded it (it took 3 hours for the 900Mb file) i was hoping its was a theme. (right-click > properties > themes.) when i tried to open it, it asked me to burn it to a disk, i did, then i restarted my computer. with the disk in, then i was running Linux mint. there, it asked me to install it, while running linux, i first pressed install alongside other operating systems.
Burf
Burf
Answer 9 years ago
Okay, you need to first determine if Windows it still on the disk. Open a terminal (command line) and C&P the following into the terminal:
sudo fdisk -l /dev/sda
You'll be asked for your P/W, type in your login P/W and then enter.  In the results, look to the right hand side under System, if you don't see this in the list,  HPFS/NTFS then Windows has been erased and you're out of luck without a backup stored somewhere else.
If it is there, then go to this page
http://www.supergrubdisk.org/
Download the "Rescatux" and follow the instructions for that program.
Good luck!
-max-
-max-
Answer 9 years ago
( A day for firm decisions!!!!! Or is it? )
o
o \_\_ _/_/
o \__/
(oo)\_______
(__)\ )\/\
||----w |
maxim@maxim-Presario-C700-Notebook-PC ~ $ sudo fdisk -1/dev/sda
[sudo] password for maxim:
Sorry, try again.
fdisk: invalid option -- '1'
Usage:
fdisk [options] change partition table
fdisk [options] -l list partition table(s)
fdisk -s give partition size(s) in blocks
Options:
-b sector size (512, 1024, 2048 or 4096)
-c switch off DOS-compatible mode
-h print help
-u give sizes in sectors instead of cylinders
-v print version
-C specify the number of cylinders
-H specify the number of heads
-S specify the number of sectors per track
Burf
Burf
Answer 9 years ago
Did you C&P the command or type it in? Because that is supposed to be a lower case letter ell 'l' not the numeral 1.
-max-
-max-
Answer 9 years ago
ya figured that out. thanks, can you decode all this and tell me if it means windows is still on here?
maxim@maxim-Presario-C700-Notebook-PC ~ $ sudo fdisk -l /dev/sda
Disk /dev/sda: 80.0 GB, 80026361856 bytes
255 heads, 63 sectors/track, 9729 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x0005686d
Device Boot Start End Blocks Id System
/dev/sda1 * 1 9347 75078656 83 Linux
/dev/sda2 9348 9730 3069953 5 Extended
/dev/sda5 9348 9730 3069952 82 Linux swap / Solaris
Burf
Burf
Answer 9 years ago
Well, bad news. That means that Windows is not on that hard disk, its all Linux and Linux partitions. Since this is a laptop, I doubt you have a second HDD, so Windows is gone.
Check your current documents folder and see if some of the old Windows dox were copied over. Depending on what you selected during installation, they may have been saved.
Grub is a menu for a multiple OS system that lets you select which OS you want to boot.
Sorry about the bad news, but I don't see any hope for you rescuing the Windows system and files unless they were copied over during the Linux installation. And re-installing windows will be a new install, not a rescue.
-max-
-max-
Answer 9 years ago
whats an HHD, an operating system? how do i reinstall windows? what are windows DOX, are they all my files, pictures, documents?
Burf
Burf
Answer 9 years ago
HDD = Hard disk drive
Operating System (OS) = Windows Vista or Linux Mint
Re-install Windows = Read the instructions that came with your laptop
DOX = Documents, etc.
-max-
-max-
Answer 9 years ago
do you know if i can copy windows from another computer and install it to my computer? or do i HAVE to buy a new version from the Microsoft site?
-max-
-max-
Answer 9 years ago
well, thanks. are you ABSOLUTELY SURE there is NO hope whatsoever? at all? :(
-max-
-max-
Answer 9 years ago
oh, and what the heck is "GRUB"?
-max-
-max-
Answer 9 years ago
is that bad, i don't see "HPFS/NTFS"
-max-
-max-
Answer 9 years ago
ignore the text rein deer, after i typed it in, it gave me all this...
V
Usage:
Options:
-h print help
-v print version
Lithium Rain
Lithium Rain
9 years ago
You can try running recovery software on it (on another computer - remove the hard drive and hook it up as an external).
-max-
-max-
Answer 9 years ago
i dont want to take apart my laptop
Lithium Rain
Lithium Rain
Answer 9 years ago
You don't have to take apart your laptop, just unscrew a cover and take out the drive.
-max-
-max-
Answer 9 years ago
i dont know anythind about the guts of a laptop
-max-
-max-
Answer 9 years ago
still, my parents won't let me take anything apart (usually, anything i touch and take apart will break)
-max-
-max-
9 years ago
also, which GRUB should i download?
