207Views3Replies
Author Options:
HELP please!! with Li Ion battery Answered
1 st question:
i have a 7.4v 2200mA li ion battery. my ip camera takes 5v 2amps
what color resistor should i use and how many ohms?
2nd quesiton:
i have a class 2 battery charger 12 volts 300mA is it good to charge my 7.4v li ion battery?
iceng
iceng
9 years ago
Just because the camera sometimes uses 5V 2A max or some times 100 ma.
You cannot pick a single resistor to reduce the voltage from the 7.4V supply..
At 2A the resistor needs to be 1.2 ohms,
at 100ma the resistor needs to be 24 ohms.
you need a 5V regulator like an 7405 or an LM317.
NO, unless you put a resistor in series and watch the temp continuously.
A
dwstar79
dwstar79
Answer 9 years ago
That makes so much sense. I went and ordered the 7405 from digi key. And will use it and soon as it comes in.
Thank you so much for your help. :)))
