419Views3Replies
HM-11 Bluetooth module: How to change the baud rate
I'm writing some code to use an HM-11 Bluetooth module
After switching on it responds to AT, AT+BAUD? etc. commands - the default baud rate is 9600, 8N1
I now want to change the baud rate to 38400. The procedure is:
1. Send command "AT+BAUD2" at 9600 baud
2. After the last command character has been sent change the baud rate of the receiver (SAMD21J) to 38400
3. Wait for the response, which should be "OK+Set:2"
The response never comes
What am I doung wrong?
Thanks for any hints,
Jerry
3 years ago
Did you forget to change to the different baud rate ?
Answer 2 years ago
Sorry for the belated reply. I changed the transmit/receive baud rate immediately after sending the last command character
Jerry
3 years ago
Read this:
http://www.e-gizmo.net/oc/kits%20documents/Bluetoo...
If you want an example of a sketch for Arduino, I have put one on my blog i am currently working on. (near the end of the blog at the time of this post)
http://tims-arduino-cybot.blogspot.co.uk/2018/03/t...
