39Views2Replies
HOW CAN ADD BUZZER TO DIGITAL MULTI METER DT830B
Hello : I have digital multi meter type DT830B not included buzzer , how can connecting the buzzer in device . This digital meter board in side IC7106CPL,
THANKS >
ALEWAN
m.alewan1966@gmail.com
24 days ago
I do not think there is an easy way to modify this meter, for to add a buzzer that sounds in the event of continuity,
https://en.wikipedia.org/wiki/Continuity_tester
between the two probes.
The easiest work around I can think of, is to just put the meter in its lowest scale resistance measuring mode, which is 200 ohms full scale. Then read what the meter says, using your eyes. If it is less than 10 ohms, then call that "continuity." Or whatever your threshold is for resistance low enough to call, "continuity."
You could even vocalize the BEEEEEP noise yourself, kind of like that guy who made all those weird noises in the old Police Academy movies.
https://en.wikipedia.org/wiki/Michael_Winslow
Also you could just buy the kind of meter that does come with the functions you want, but you know, that might cost more.
;-P
24 days ago
Why would you need a buzzer?
The only reason for having one would be to test for continuity without looking at the display.
And usually that buzz you miss then happens in the diode testing mode on these cheap toys.
