8328Views8Replies
Author Options:
HOW CAN I GIVE MY MOUSE TRAP CAR AN EXTRA SPEED BOOST (LEGAL OR ILLEGAL>>>DOES NOT MATTER TO ME)? Answered
There is most likely a reward in my science class for the fastest mouse trap car........ any advice.
Squoobmonger
Squoobmonger
Best Answer 11 years ago
Take some handheld electric fans, take out the motor, and bring batteries.
Spud2
Spud2
7 years ago
my names phil and i find this very offensive
so could u plz stop this madness.
or else
manndude1
manndude1
10 years ago
I am working on one now too. biger the wheel the farther it will go for each axel rotation, the thinner the axel the more wraps you can get from your strin around the axel, the longer the string the more wraps you can get along your axel. the stronger your mouse trap, the more inertia to keep car going after its done powering.
Madrias357
Madrias357
11 years ago
Equip the biggest bloody mouse trap (or rat trap) you can get your hands on.  Also, you'll want as much tire grip as you can get, so put rubber bands on your tires.  Finally, you'll want it to have a good mix of acceleration and maximum speed so that your car will go fast in a hurry.
The legal way to do this.
Madrias357
Madrias357
Answer 11 years ago
Also, I forgot one last second thing: if possible, use 2 traps...
xACIDITYx
xACIDITYx
11 years ago
I suppose you could try to use different rubber bands, or on a more over-the-top approach, use a model rocket engine.
Squoobmonger
Squoobmonger
Answer 11 years ago
I could have told him that, but he never asked.
652800
652800
11 years ago
I would suggest that you take a long, light piece of wood (such as balsa) and attach it to the spring arm of the mousetrap, enabling you to wrap more string around the axle and get more range
If range is not a concern, take a light plastic, and make a vacuum formed covering for it to significantly reduce drag
You could also make it three wheeled, reducing the drag on the ground
In addition, check out these instructables (if you haven't already)
Foam Mouse Trap Car
Rat-Trap Car
And good luck with your contest!
