HI Mpilchfamily i mean if can be applicable to invert 12vdc to220vac without using transformer by using clipping ccts & dc chopper ccts? thanks for your time blessing you,,
you went so far from my question,,, deeply I ask some one can use capacitors, votage doubler circuits & chopper techniques to convert from 12vdc to 220vac square wave even for alimit power ,,Is the above cann't absolutily be applicable even for amperage fractions.
Best Answer 8 years ago
Are you wanting to go from 12VDC to 220VAC, or 220VAC to 12VDC?
Answer 8 years ago
HI Mpilchfamily
blessing you,,
Answer 8 years ago
If you don't know a lot about electrical engineering then don't attempt to build your own 12VCD to 220VAC Inverter.
You can't get around using a transformer when building an Inverter.
Answer 8 years ago
8 years ago
Why ?
Answer 8 years ago
many wise only !!!
