189274Views40Replies
HOW TO BYPASS COPYRIGHT ON VHS TO RECORD TO DVD?
I got a vhs to dvd recorder and trying to convert vhs tape to dvd but some of the tapes have some type of copyright protection and will not allow to be copied is there a mod or device that a can use to bypass the copyright. I am just coping these for own use.
9 months ago
You need to bypass audio and video from VHS player to other Video Receiver (TV, VCR, AMP) to digitalizer, normally you don't need to do this with Easycap and Dazzle, but I made this on 98 with some tapes; now I have my copy on DVD and the VHS tapes now are unplayables due lack of players; now I'm thinking to make them MP4. Tabs on the Tapes are to enable or disable recording on the same tape, like small switch on the SD cards
9 months ago
That tab is missing on VHS tape to keep you from ACCIDENTALLY COPYING OVER an existing tape.
1 year ago
How do transfer vcr to DVD when there's a copy right protection
1 year ago
I'm pretty sure most of the Hauppauge WinTV PCI TV tuner and capture cards ignore the Macrovision protection. (They also handle both NTSC and PAL video formats, if you have a foreign camcorder and tapes.) PCI capture cards could be found at computer recyclers like Freegeek.
1 year ago
The GREX works, but the picture quality suffers a little; it's softer. There's another product that's better...
1 year ago
Xdimax. $90 on Amazon. It's pretty much plug and play. Super easy and doesn't require really any tech know-how.
11 years ago
Route the AUDIO cables DIRECTLY to the recorder... but connect a VIDEO CAMERA to do the VIDEO input of the recorder. Aim the video camera at the TV screen. You will loose a litte bit of picture quality, but so what. ALSO you will GAIN one advantage.....: I have found when recording from tape to DVD there is often a problem. If the videotape has ANY sudden drop-out of signal--- then the DVD recorder will fail the recording. It might have something to do with DVD copy protection (i'm not sure). Even videotapes that are NOT copy protected will have OCCASIONAL video drop-outs. So the method of recording the picture portion with a VIDEOCAMERA overcomes this signal DROPOUT problem.... because signal may drop out from the tape... but the CAMERA sends a continuous signal anyway !! NO DROPOUT.
This system of copying works on any encryption method and will record very OLD videotapes that have poor pictures... hope that helps. framistan
Reply 1 year ago
Is this a serious solution? Sure, the audio will be passable, but actually film a shot of your television?
Answer 4 years ago
This is laughable at best.
2 years ago
wondering if it is possible to tape only part of the vhs tape to dvd any help appreciated...
2 years ago
from grex
2 years ago
maybe i should try a red pro copier
2 years ago
hello
my name is lisa steelman i have a dvd recorder from toshiba and a combo player from philips i'm trying to copy the commercial vhs tapes onto dvd and how do i make dvd copies to enjoy because i'm not selling the dvd's to my friends and they are not buying them from me how do i make them with out getting in trouble
3 years ago
I tried copying vhs tape to dvd using a toshiba vhs to dvd recorder and ran into same problem. Solution I came up with is; I had a gadget called easycap https://www.amazon.ca/EasyCAP-DC60-Creator-Capture-High-quality/dp/B002H3BSCM , used the vcr just like a vcr, I played tape and hooked the rca plugs into the easycap . I am using ubunutu 16.04, recording program is webcam cheese. You have to unmute easycap by typing in the terminal, amixer -c stk1160mixer sset Line unmute cap , or vistit (http://easycap.blogspot.ca/2014/04/activate-audio-for-stk1160-device.html) to see the steps, for you to be able to record the sound in webcam cheeze in ubuntu. doing it this way you get a digital copy and you also avoid the copyright. Hope this works for you all, it worked for me!!
Reply 2 years ago
Thus us way too complicated for me. Is there an eadier, less techie, method? I have a Magnavox duel player that I'm working with. Recording VHS tapes to save space for downsizing. Thanks
Reply 2 years ago
i have the same trouble with my vhs tapes i can't put them on dvd
2 years ago
how to put a nice label onto dvd
3 years ago
I did what /MahavishnuMan said below and it works perfectly. You buy something like Divmax and hook it up to the 2nd VCR and also to the DVD burner. It eliminates the copy write protections on all VHS tapes or DVDs. I guess in theory, you can use a second DVD player and hook it up the exact same way and make a second copy of a DVD (for your own personal use of course). http://www.xdimax.com/grex/grex.html
So hook up the yellow video rca cable from the VCR or DVD player that you want to copy from and plug into the Dimax In. Plug the red and white rca cables from that same VCR or DVD player into the AV1 In on the back of the DVD burner. Then plug a single yellow rca cable into the Dimax Out and plug the other end into the back of the AV1 In yellow video port on the back of the DVD burner.
It works!!!
4 years ago
I have the same problem so what I do is: look on you tube or other site for the movie and copy it to computer via torch browser. then convert it to dvd format and burn it to disk.
11 years ago
If it is a VHS movie that you purchased, then the tab pictured below is removed to prevent you from accidentally writing to it. Put a piece of tape over it and the machine should bypass it.
Answer 4 years ago
Wrong.
Answer 7 years ago
I tried the tape over 2 different copy write protected VHS pre-recorded movies. It didn't work, I tried to record both and I still got an error message both times. My question is: What type of tape are you using and why doesn't it work when I try it?
Answer 8 years ago
I got a vhs/dvd recorder where I can transfer vhs to dvd, I was able to do it with old vhs that dont have copyright and they work, but I can't do it with newer ones. And i have try what you are saying here but I dont know if it didnt work because the piece of type was too big and it cover more than just the square or if it just dont work? But I really want to transfer my vhs just for my own use and by trying to bypass the copy right I have mess up DVD R disc and now I cant use them again and I dont want to keep doing that. Please Help me.
Answer 10 years ago
Taping this removed tab only makes it possible to copy ONTO this tape. It does not make it possible to copy a macroencrypted Vhs tape.
Answer 10 years ago
I must have misread the question when I wrote the answer. Thanks for correcting my mistake.
Answer 10 years ago
Trial and error. I thought it might work...but it didn't. I don't want to spend more money to get this task completed and clean out years of old VHS. But I guess I am going to have to break open the piggy bank!
5 years ago
I'm a DJ and wanted t download my videos down to a DVD and ran into the same problem. Here is a link I found via google: http://www.amazon.com/gp/customer-reviews/R21D5Q58SHWNHS/ref=cm_cr_pr_viewpnt?ie=UTF8&ASIN=B003YGJLWU#R21D5Q58SHWNHS
5 years ago
This is just crazy, lol, I am only here from having a failure attempting to copy home videos from vhs to my PC. Get copyright protection errors on most tapes. Spent money on a capture device and still can not copy most tapes (all are recorded personal tapes - not trying to cheat). Most are from old bands I was in (live shows), rest are home recorded memories - none are copyrighted. I should be able to turn off this antiquated function. Using ArcSoft Showbiz 8 (came with device), and Hauppauge usb live2. Not sure if it is the unit, or the software that is reading this incorrectly. Just kinda feel cheated not being able to copy these old tapes. Not a newbie or novice on PC's. I know these tapes are old and have not been stored in the best of environments, so the video will drop out here and there a bit. Just feel it should be ignored (turned off). I know it is reading it as Macrovision, but it is not. In the day of these tapes, I have made multiple copies for the other band-mates from one vcr to another - with no problems. Now I can not copy the originals to my pc. Any fresh ideas/tweaks? Again, this is not copyrighted material, no laws being broken. 1st tape went fine 2, 3, and 4 failed with the copyright protection error. 1st tape plays great on the pc, considering the technology and age.
5 years ago
buy a digital video stabilizer this will get rid of that problum
http://www.ebay.com/itm/121714889075?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
6 years ago
I've said it before and I'll scream it again... I HATE TECHNOLOGY!!!!!!!! What are we supposed to do with all those great VCR movies that cannot be viewed anymore?
My family and I are in a movie and there is only one VCR copy among us. AND only one among us still has a working machine to watch it!! I'm going to call a video production\transfer company and ask if there is anything that can be done to bypass or over ride the copyright, as soon as they open. Like I read from someone's comment... I want to copy the movie for my own use - to watch, share and have forever. Technology sucks!
Answer 5 years ago
Types "I hate Technology" on a computer that sends it to the internet. Oh the Irony.
5 years ago
how do i copy a vhs movie to a dvd? In simple english, not that good with high tech.
6 years ago
I have a toshiba dvr620ku and its a combo dvd vcr player and recorder when I try to record a vhs to dvd with a disney movie it comes up with a copyright block and wastes a disc by recording 30 seconds if I do a home movie it will copy how do I get around the copy right when I do the disney movie I do not put tape where the tab use to be and the home movie doesn't have the tab on it or the tape so why does the home movie work and not the Disney movie please help u can also email me at kevinloveshisiphone@mac.com thank u
11 years ago
What type of protection is it? Does the copy come out too dark or squiggly? Or do you get a message on the screen saying that you can not copy this tape?
IF it's too dark or wavy then there is a cure for that. Radio Shack used to sell it but probably not now. You want a video enhancer. It will add the stabilization and the color back into the tape. That type of copy protection recorded the details just barely readable and when copying you lost enough detail that the copy wasn't useable.
For the other kind that tells the dvd not to copy, I don't know how to get around that but I don't thing VHS tape does that.
Answer 6 years ago
That's actually the same type of copy protection. Newer machines simply detect the protection and automatically abort the copying process.
11 years ago
Like the other guy, I would suggest a device similar to what he said. I use one that has 3 composite connectors and plugs in via usb. my vcr can put video out in composite and right into that reciever and then computer.
Answer 8 years ago
I read somewhere, and haven't had a chance to try yet, that if you have two old vcr's you can run the video from one vcr to the 2nd and from the 2nd to the recorder (in my case I'm putting direct to PC) and that will cancel the macrovision protection.
11 years ago
VHS protected? Man I didn't think video got advanced enough to stop you copying on a future system.
I copy VHS via my PC which has a composite-video-in - what does your machine have on the graphics-card (next to the monitor connection)?
L
Answer 10 years ago
They didn't put any copy guard type thing on video tapes in the UK?
Answer 10 years ago
It's analogue - how do you do that?
L
11 years ago
This copy-protection is known as Macrovision, and can cause scrambling of the image or dimming every few seconds. The VHS/DVD combo systems out there are designed to comply with this protection to prevent you from copying it (as they couldn't legally sell you a unit that just lets you do it).
The simplest way is to get an external VCR, and run the composite cables out to an RF modulator. Run this into the DVD recorder. The RF modulator will effectively remove the Macrovision (at the expense of slight loss of quality).
