489Views2Replies
HOW TO PRODUCE MORE THRUST IN A REMOTE CONTROLLED QUADCOPTER ? 1]LONG PROPELLERS LESS RPM or 2]SMALL PROPELLERS MORE RPM
I ALSO NEED ANY RELATIONAL FORMULA BETWEEN LENGTH OF THE PROPELLERS , WIDTH OF THE PROPELLERS , RPM (rotation per minute) AND THE THRUST PRODUCED .
ANY OTHER DETAIL ABOUT QUAD COPTER ( or any other flying vehicles ) CAN ALSO BE STATED.
THANK YOU!!!!!!!!
6 years ago
If you want to make a long propeller, then you can have low rpm, but if you want to make small propeller, then the rpm should be high and the no. of propellers should be a lot more than one to equal the thrust produced by the long propeller.
6 years ago
Caps is BAD.
I can do little better that suggest STRONGLY that you watch the videos produced by flitetest on Youtube - they will answer most of your questions you may have now and in the future.-
https://www.youtube.com/user/flitetest/featured
To start you off - The prop you use has 2 properties, pitch and length. Which prop you use is closely connected to the motor you have .
Put a bigger pitch or longer prop on and you will effect the thrust BUT you will also effect the motor current, possibly to the point you burn out the motor.
Flite test show you how to measure the thrust and motor current to choose the most effective setup.
