It sounds to me like:
A) Your LCD needs a new inverter (usually the hottest part of the screen).
B) You might not be getting a good ground. Try checking if there is a grounding screw in the computer that is loose.
C) If all else fails, you might need to order a new screen.
Hope that helps
11 years ago
It sounds to me like: A) Your LCD needs a new inverter (usually the hottest part of the screen). B) You might not be getting a good ground. Try checking if there is a grounding screw in the computer that is loose. C) If all else fails, you might need to order a new screen. Hope that helps
