622Views7Replies
Author Options:
Hall effect threshold circuit? Answered
For a project that I'm building, I'm using an A1302 hall effect sensor. My goal is that if the sensor senses a magnet closer to it than a fixed threshold, it will pass a voltage through a relay (that would act as a Z axis endstop for my 3d printer). What would be the simplest way to achieve it, without using any microcontroller or anything more complicated than resistors capacitors and transistors, , without frying the components with the PSU, and with a high sensitivity?
Thanks in advance!
iceng
iceng
Best Answer 4 years ago
Please click on the pic to see the entire image...
yonch
yonch
Answer 4 years ago
Thank you so much! I'll try it as soon as the parts arrive. Will it work for 5V/12V? That's what my PSU supplies.
iceng
iceng
Answer 4 years ago
5v to 6v Yes... 12v NO ! because the A1302 is a only a 6 volt device..
Downunder35m
Downunder35m
4 years ago
Just as an alternative:
All good 3D printers either use mechanical or optical endstops for a good reason - you might want to try it ;)
yonch
yonch
Answer 4 years ago
After about a year with a micro switch I've decided to find a different method. I had to re-adjust it after every few prints. What kind of optical switch is normally used?
iceng
iceng
4 years ago
You will need a disengage feature to be able to move out of the overun axis Estop.
Downunder35m
Downunder35m
4 years ago
Simply use a purpose build sensor, available from many suppliers....
Connect to 12 or 24V, adjust the output as (distance) as required and off you go.
Easier to use on a metal bed than trying to produce a magnetic field throughout the plate that a hall effect sensor can detect.
Keep in mind they detect magnetic fields ;)
