5305Views9Replies
Has anyone made their own briquette or log maker such as the ones Eko-Mania makes?
I have not been able to find a diy version for such a thing. These "machines" recycle newspapers etc into logs or briquettes that can be burned in woodstoves and bonfires.
http://www.eko-mania.com/
They have one that uses wet paper and one that uses dry.
I am not looking to roll sheets of newspaper though.
Best Answer 11 years ago
Seems to just be a mold for pressing paper pulp into a block. If you make a rectangular frame out of 2x6, attach some expanded metal on the bottom, and cut a plywood press block that fits into the open top part, that's pretty much all you need, I think. Fill the mold with wet paper pulp, place the plywood press block on top, and stand on it until the water is pressed out. Remove the press block, turn the mold upside down and bang it on the pavement a couple of times until the pulp block pops out.
5 years ago
These are easier made than many sites and videos would have us believe. Many of these productions represent overkill on the technology (jacks, levers, screw presses, etc.) and list unnecessary ingredients (like flour for binders---Why waste good food!). I make biomass paper mache logs from junk mail. The junk mail seems to bind better with less preparation in shredding than newspaper, but both work well. Newspaper doesn't seem to set up as well as does the better quality paper in junk mailings (just be sure to remove the cellophane windows before shredding---and go easy on paper shredders---most are not heavy duty---and be sure you have all the staples out, for they can wreck a machine. I use two to three days soak time in a five gallon bucket. This softens the paper strips, but before I mold the logs, I further pull apart (hand-shred) the paper to make the fibers looser so they will coalesce better when pressed. I mold in a perforated pvc pipe, merely loading it with pulp and squeezing. (You choose the ultimate length of log you want. Short ones "eject" from the pipe easier!) For complete instructions see my article:
http://deomnis.net/2015/09/25/easy-to-make-paper-mache
8 years ago
my briquette machine project:
https://plus.google.com/u/0/photos/112434933654703111037/albums/5816274005212698465
8 years ago
Hey, you don't need any fancy equipment to make briquettes. I make all of mine with a caulking gun and it works great!
http://www.youtube.com/watch?v=7MmuFg7aAK8
You don't have to put separators in the gun to make lots of small bricks. You can leave out the separators and make a small log if you like. All you have to do is drill holes in the lower half of the gun barrel.
11 years ago
see the comments here:
https://www.instructables.com/id/Intro_1/?comments=all#CKCZ6JXFTO54J9T
I am still experimenting with this, but it seems to me that the presses don't really offer rmuch mechanical advantage, you can mould them in your hands to look like big lumps of coal, it is easier than the press.
I think making long thin ones for a rocket stove would be good though.
Answer 10 years ago
I did forget the Rok stove. It uses round briquettes right off the bat:
http://www.youtube.com/watch?v=L1t6eD9Ijwc&feature=related
You can also burn these briquettes more efficiently in any gasifier stove. Check out my other Instructables for a $50 high power gasifier stove.
Not for indoor use though. Although you can burn briquettes in a typical wood stove.
Answer 10 years ago
The real briquette presses put hundreds of pounds pressure per square inch on the material. Makes a dense long burning briquette. Can't do that with bare hands. The round briquette press idea has been around since 1980.
My Instructible has all the info. Go there.
Then watch all the related Youtube videos. There is a whole education out there.
Once you see it all, you will come right back to Lee's press.
Answer 11 years ago
Thank you for pointing me towards that instructable.
However, your idea of moulding them with your hands isn't quite what I'm looking for. I don't think I have the strength to do it that way.
Thanks though!
10 years ago
Make a press with my instructions and the plans from Lee Hite:
https://www.instructables.com/id/Biomass-Briquette-Lever-Press/
This is a smaller version of ones they use in Africa etc..
