1075Views3Replies
Author Options:
Has anyone tried hacking a Cricut Machine to cut thicker materials? Answered
My grandmother gave me her Cricut craft cutter and I would like to use it as a mini CNC machine. I found plenty of software hacking links but not much on hardware. From what I've researched it doesn't cut deeper than 1.5mm. Thanks.
Tags:cricut
orksecurity
8 years ago
Depends on what kind of cutting mechanism it uses. From the description, I would suspect it's using a drag knife or something of that sort, which limits which materials it will be able to cut.
Operating on that assumption: You might be able to cut deeper by making (accurately) repeated cuts over the same lines...?
gtoalorksecurity
Answer 8 years ago
It's not the depth of the blade that's the problem (you can get a deeper cutting blade), it's the space underneath the rollers that is tight. You would have to find a way to raise the rollers and keep them working properly in order to cut anything significantly deeper. I tried to cut scratchboard and failed dismally.
Graham
kelseymh
8 years ago
If he doesn't post here directly, you might try either a PM or an Orangeboard posting to user j.l.larson, who has done some nice Cricut mods.
